Corvette Forum
Go Back   Corvette Forum > C6 Corvette, 2005 - ???? > C6 Z06 Discussion
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C6 Z06 Discussion
General Z06 Corvette Discussion, LS7 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track Sponsored by
PFYC
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-03-2009, 03:44 AM   #1
Myhardtop
Supporting Vendor
Myhardtop's Avatar
Default FAST Intake,Tested & Re-Tested. Long reading!
The grueling FAST intake testing is now complete. The test car had the following mods: Bully Cam, ARH, Vette-Air scoop, Killer Bee, 160 stat and yes, a ported LS7 intake.
It has been super hot here in Dallas Texas, if you live here then you know how hot it has been these past few weeks; we are talking no less than 100* days or worse with the heat index.
As many of you guys know by now, our first FAST intake test was a bust. We literally spent the money and purchased 5 units just to test. Initially our idea was plain and simple: open this thing up and see what happens. That approach did not have any positive returns because for many streetcars, air velocity is better than air volume…the LS7 intake is not all that bad if you have a stock or mild cam.
We later realized that perhaps we needed to revisit the fueling approach of this set up and in doing so, we discovered that our LS7 stock injectors just didn’t quite cut the mustard; so we decided to install a set of 60lbs Siemen’s injectors. These injectors combined with the higher flow capabilities of the FAST intake proved to be the key elements of our winning combination.
As with any modding endeavor, tuning is key, and these FAST intakes are no exception.
These intakes flow more air…period! You will need to tune even if you choose to leave your stock injectors in place (not recommended). The FAST KPA readings were at 100% during all the test runs where the ported LS7 readings were best at 97% KPA. In case you didn’t know, 100% means no airflow restrictions; which is also a clear indication of our port/clean up job on these intakes…. more on that later.
Now to the good stuff, we finally got the FAST intake to work. As previously mentioned, we had 5 units for testing and ended up trashing one due to our own greediness…yeah, more/bigger is not always better! In the end, we ended up with three FAST units: Virgin FAST, Cleaned up FAST and Ported FAST.
The Virgin FAST vs. Ported LS7 was almost a dead heat; we noticed gains of 3rwhp/4rwtq after some MAF table tweaking…not too shabby.
The Ported FAST vs. the Ported LS7did not offer any gains even after tuning. We were baffled; perhaps the full porting approach is best suited for bigger motors with high compression ratios, ported out heads, FI and NOS application. The bigger dose of air ingestion may be too much for the stock LS7.
The cleaned up FAST was the winner in our test. The GM LS7 casting is pretty good compared to the FAST. Heck, we noticed that in some cases some of the runners in the FAST had different openings sizes…yeah, isn’t that crazy?
As you can see from the Dyno sheets below, the best ported LS7 produced 521.8/489.0 VS. Clean-up FAST 537.0/512.5! Look at the run conditions, but better yet, look at the power under the curve! In some areas under the curve, the FAST made over 25rwtq vs. the ported LS7. It averaged roughly 20rwtq and 16rwhp during the entire curve NOT just at peak. And believe me, you can feel it on the streets especially as speed increases. Now do you see why I would opt for the bigger injectors?
Forget about the bigger TB for now, no gains were recognized and it takes a bundle of time to tune plus the cost is insane…save your money and get the injectors!
I believe we took a scientific approach during testing. As always, we took into account coolant temps, ambient temps, air temps, DA and so on. Our FAST clean up procedure consisted of taking apart the unit, setting the base of the unit on the heads and matched each runners to the LS7 heads intake ports. YOU MUST do this in order to have clean and smooth air flow. We created a guide plate off the stock LS7 head and FAST so going forward all clean up will consistently match. We also clean matched each individual runner, which bolts to the base eliminating casting flaws and thus avoiding air turbulence.
As previously mentioned, it has been super hot here in Dallas Texas and we believe greater power will be had under better conditions. If you cared to compare apples to apples, then check this: the test mule made 540 to 540 plus during 65* to 68* air temps; with air temps in the 100* range, she was making between 518 and 522; down about 20 ponies due to heat, all else was the same.
Under the same crappy and steamy conditions, the FAST intake made almost the same power the car was making under cooler/better conditions. I am pretty confident the FAST would be about 15 to 20 rear wheel better in both the HP and TQ dept. under cooler conditions. In my opinion, our 537.9 ponies in this steamy, heated and thick air is pretty darn good. I can’t emphasize enough how hot it has been here in Dallas Texas…those who live here can attest to this. Heck man, look at the run conditions and we did around 49 pulls in three days!!!
Well there you have it folks, we took the time for testing, spent the cash to buy all these intakes and sweated many gallons of water just to find out what this new product can do and bring you real world results. It was not easy and it kicked our butts, but in the end I think our ideas, tuning and FAST cleaning approach prevailed.
Your result may vary; you may make a little less or a little more. In my book, if a car can make between 12 and 15rwhp and between 15 and 20rwtq throughout the power curve in this heat then it’s worth it. And remember, many of you can tackle this job in your driveway in 1 hour (1st timers) or less than 30 minutes for those who have swapping intakes experience.
If you are interested, we will be putting a package together and I believe we will keep it under $2K with free shipping for now…mail order tuning will be available and of course, local install and tuning will available as well. Heck, headers are about the same price and they do not give you this type of ROI right off the bat, and many of you can’t install them.
All right, we did our part now let the questions begin… Oh yeah, not all tuning secrets will be shared but we will sell them…LOL.
Many thanks go to Manny and Chris from HPP; I drove those guys nuts and their input was very valuable. Thanks to Patrick and Keith for helping me keep my head above water and for the encouragement.
Thanks,
Carlos
www.quality-motorsports.com
__________________
www.vette-air.com
Myhardtop is offline   Reply With Quote
Old 07-03-2009, 03:54 AM   #2
hpaddict
CF Senior Member
hpaddict's Avatar
Damn't Boy, Now that's what I'm talking about!!
Thank You Carlos for all you do
Now tell us how much we can get the whole package for, injectors included It would seem that the price of the 60's would be offset a little by not having to purchase the adaptor kit that would be required to run the stock LS7 injectors anyway correct?
hpaddict is offline   Reply With Quote
Old 07-03-2009, 03:54 AM   #3
kumar75150
CF Senior Member
kumar75150's Avatar
Send a message via AIM to kumar75150 Send a message via Yahoo to kumar75150
in
when do i get mine?
kumar75150 is offline   Reply With Quote
Old 07-03-2009, 03:54 AM   #4
kumar75150
CF Senior Member
kumar75150's Avatar
for more "testing"
Old 07-03-2009, 03:56 AM   #5
hpaddict
CF Senior Member
hpaddict's Avatar
And boy do those graphs really tell the complete story. Great job guys!!
Old 07-03-2009, 03:56 AM   #6
dfinke23
CF Senior Member
Support Corvetteforum!
dfinke23's Avatar
Were you running the larger injectors with the ported LS7?
dfinke23 is offline   Reply With Quote
Old 07-03-2009, 03:56 AM   #7
Evilness
CF Senior Member
Evilness's Avatar
Send a message via AIM to Evilness
Awsome carlos its been death hot here in AZ as well im still on the fence about one of these... BUt ur effords are greatly appreciate it..
R.
Evilness is offline   Reply With Quote
Old 07-03-2009, 03:57 AM   #8
kumar75150
CF Senior Member
kumar75150's Avatar
ok i read all that
if the bully picked up 15-20, i am hoping for 25ish :fingerscrossed:
Old 07-03-2009, 03:59 AM   #9
Myhardtop
Supporting Vendor
Myhardtop's Avatar
Will post more pics and NOS dyno graphs later but for now, please chew on the above. Below is another run condition sheet.
Keep this in mind: if you do not have a cam and exhaust, then this FAST mod may hurt your performance!
I think our Street Bully cam and certainly the QM600 and ready for purchase Street Menace and the upcoming Black Mamba cams will benefit greatly with our modded FAST intakes and tuning combo.
You QM600 and Bully cams guys out there let's talk; don't get left behind, stop by and talk with Patrick.
If you are out of state, we have mail order tunes available; you can always get the entire package as well through our plug in and play SCT tuner option.
Thanks,
Carlos
__________________
www.vette-air.com
Old 07-03-2009, 04:06 AM   #10
Myhardtop
Supporting Vendor
Myhardtop's Avatar
Quote:
Originally Posted by kumar75150 View Post
ok i read all that
Greedy...LOL
Is hot here as you know. I think you may see your 20rwhp gain. We had a couple of 20's rwhp gains but as you may know, we like posting average runs, not just one or two best runs.
We are finishing your intake by end of the day tomorrow or Saturday. We are closed but will swing by to tie up some loose ends. How about stopping by next week so we can slap that sucker on and see how it does with your combo?
PM me
Thanks,
Carlos
__________________
www.vette-air.com
Old 07-03-2009, 04:09 AM   #11
Myhardtop
Supporting Vendor
Myhardtop's Avatar
Quote:
No. The ported LS7 injectors set up was left all in tact as delivered from GM. Good question.
Thanks,
Carlos
__________________
www.vette-air.com
Old 07-03-2009, 04:13 AM   #12
dfinke23
CF Senior Member
dfinke23's Avatar
Quote:
Thanks,
Carlos
I'm running 65lb FAST injectors in a ported LS7 intake and immediately noticed a difference.
Old 07-03-2009, 04:13 AM   #13
kumar75150
CF Senior Member
kumar75150's Avatar
Greedy...LOL
PM me
Thanks,
Carlos
cool
Old 07-03-2009, 04:15 AM   #14
Myhardtop
Supporting Vendor
Myhardtop's Avatar
As of right now, we are looking at roughly $1,940 shipped!!!!
That includes the FAST intake, Cleaned up job, New Fuel rails and New 60lbs injectors.
You are right, the injectors jack up the price a bit but man they are much better. You should see and feel how they work with a little 100hp dry shot...ay caramba!!!
Thanks,
Carlos
__________________
www.vette-air.com
Old 07-03-2009, 04:18 AM   #15
Stingray23
CF Senior Member
Stingray23's Avatar
so what exactly will the kit include?
Stingray23 is offline   Reply With Quote
Old 07-03-2009, 04:19 AM   #16
kumar75150
CF Senior Member
kumar75150's Avatar
how much power are the 60s good to?
Old 07-03-2009, 04:19 AM   #17
Myhardtop
Supporting Vendor
Myhardtop's Avatar
Yep. Then you know what I mean.
These 60's simply seems to make the car run smoother, rev better and feel freer just like my old TT days.
Thanks,
Carlos
__________________
www.vette-air.com
Old 07-03-2009, 04:43 AM   #18
Myhardtop
Supporting Vendor
Myhardtop's Avatar
Quote:
Mr. Stingray,
You get:
A New FAST intake
All casting clean job matched to your stock LS7 heads
New Fuel Rails
New Seimens 60lbs injectors (8)
And FREE shipping!!!
Some vendors are selling these intakes out of the box for $1,200 only plus shipping. Our deal is one of the best out there and ot comes with all the above.
Thus far, our top notch cast cleaning job service, tuning and overall combo worked.
Carlos
__________________
www.vette-air.com
Old 07-03-2009, 04:46 AM   #19
Stingray23
CF Senior Member
Stingray23's Avatar
Thanks Carlos
Old 07-03-2009, 04:46 AM   #20
Myhardtop
Supporting Vendor
Myhardtop's Avatar
From my past experience, these babies can handle at least 730rwhp with no problems.
Heck, my stock crap was handling 720rwhp at only 88%.
Thanks,
Carlos
__________________
www.vette-air.com
Reload this Page FAST Intake,Tested & Re-Tested. Long reading!
Tags
corvette, ev1, fast, injectors, intake, jerry, kpa, ls7, lsxr, maf, manifold, sct, tests, tube, wroblewski
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
