[Z06] Blown engine
Blown engine
Today on my way home from work between 4k - 5k in 2nd gear half throttle big bang with vibration lots of smoke no oil pressure. Pulled over to side of street. Called tow truck. Lots of metal parts on the street piston, block pieces, and a bent connecting rod. I had the car sent to a dealer. Car is a 2007 16,000 miles do they usually just put in a new engine in these cases or try to fix up what is left? Car is completely stock. If they are in there fixing it should I have a clutch put in? I got it back about a month ago because of broken rockers and they replaced them all.
unbelievable, as much as i love my LS7 i dont understand why they grenade so much. Hell LS1s were bulletproof although they werent making as much power it doesnt matter. What the Hell GM
They probably won't choose to JB Weld the block and pistons together. You get a new motor!!!
I picked up most of the pieces maybe if they are really carefull they can make up a piston or at least patch the block with duct tape and the parts I gave them. The tow driver kept the rod for a prize.
Was the car modded?
Jim
Man that sucks. 3x in for broken rockers sounds like there might have been that piece of metal floating around in the oiling system.
Ask to see the valve train when they pull the engine, you might be able to make a lemon law case and get a brand new car.
Jay
Jay
Since the op said he got it back from having the rockers changed, one would assume that one or more rockers lost their needles, which would cause a few "bad" things to happen later on if they get sucked through the oil pan, which is, by the sound of it, exactly what happened. The left over needles probably got sucked, and either blocked off the oil passages or were ground into fine metal which took the bearings out, and caused them to seize, and at 4-5k, that's never pretty!
Time to become an irate customer and get not only a new motor but the upgraded 09 resevoir. It is the least they should do after what you have been through with this car.
JMHO
JMHO
My 06 launched last year just driving to the gas station.16k miles.Lost #1 piston and rod.The dealer replaced it and I traded it for a forged engine from QM in Texas.Good luck with your new motor.Gotta love 5yr/100k warenty.
5/29/08, which would have been "last year" as you say above, is that when she gave up the ghost???: http://forums.corvetteforum.com/c6-z...post1565663547
Lost my engine at 17100 miles on the way to the gas station.Pulled shifter outta 3rd to 2nd to turn in.The motor locked up.Oil presure was good.I was watching with oil temp cause I just had started it and left the house.Twice in the time I've owned this car I'd try and start it and it would just make a clunking sound?Go back later and it would start.New motor under warrenty.When dealer tried to start old motor,#1 rod came out of the side of the block.The car has never seen the track or the strip.Service was great,Classic Chevy in Texas.We were on a road trip at the time.
But before that, 09/05/07 ????
http://forums.corvetteforum.com/c6-z...bout-mods.html
Anybody thinking of modding thier Z06 needs to put Carlos at the top of the list.Carlos has spent countless hrs with me on the phone.I've got his cam&springs,Vette Air,160 stat,ported TB&intake,ARHeaders Killer Bee, and tune,which took many hr's of work.Now that everything is working together car is Unreal! Can't say enough! Carlos is the best kept secrete on the web.Now I need to get it on a dyno. Tom
I'm sure that some here are trying to get a feel for how well, or not, these engines hold up when stock.
http://forums.corvetteforum.com/c6-z...post1562905422
Pardon me for asking bro, but in all fairness, is there really any wonder that she popped, on the way to the gas station, after the above?
I brought this up in previous post. We put the Z06 in a winning pedestal and we call it "supercar" but we should think twice. This forum is filled with owners that don't even race their cars and unfortunately have their engines destroyed.
The Z06 is a great and fast car but not as good as we claim. Things like this and the oil starvation issues are simply one of many Achilles tendon
