Corvette Forum
Go Back   Corvette Forum > C6 Corvette, 2005 - ???? > C6 Z06 Discussion
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C6 Z06 Discussion
General Z06 Corvette Discussion, LS7 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track Sponsored by
PFYC
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 04-21-2009, 01:12 PM   #21
GMuffley
CF Senior Member
Quote:
Originally Posted by Lawdogg View Post
Probably longer than you'll live
GMuffley is offline   Reply With Quote
Old 04-21-2009, 01:28 PM   #22
robvuk
CF Senior Member
robvuk's Avatar
Send a message via AIM to robvuk Send a message via Yahoo to robvuk
Quote:
Originally Posted by BEZ06 View Post
I'm not sure what the issue is with shock mounts failing, but I guess it's enough of a problem that LG made this video to show that theirs isn't going to give you a problem:
http://videos.streetfire.net/video/L...ver_164939.htm
I don't know what people are doing while street driving that would cause a shock mount to fail, but I'm not worried with my stock suspension.
Bob
Aren't coil overs supporting some of the weight of the car on the shock towers instead of where it was designed? The shock towers were designed for shocks, not springs. It should be no surprise that there might be some failures from doing that. I personally wouldn't bother so I'm not directly familiar with that situation. This is just a theory here.
robvuk is offline   Reply With Quote
Old 04-21-2009, 02:06 PM   #23
DSOM Z06
CF Senior Member
DSOM Z06's Avatar
Quote:
I hope that Pfadt has corrected that with the new Delran(sp?) mounts that are on all of the new-style coil overs that they sell. Otherwise you do have me a bit nervous.
DSOM Z06 is offline   Reply With Quote
Old 04-21-2009, 02:08 PM   #24
BEZ06
Formerly beezeye
Support Corvetteforum!
BEZ06's Avatar
Yes, you're right - the whole suspension system was designed to work well with the stock leaf springs, and I find they work great on the street and the track.
I'm just an HPDE guy, and the leaf springs work great for me. I guess if I were a W2W racer and looking for every 1/10th of a second I could get that I'd consider anything that might give me that extra edge. But, for the street......
I guess beefing up the mount is one of the things that LG has done with their coilovers - in the video he shows a mount that spreads the forces, and the video shows pretty convincingly that it works well.
Bob
__________________
BEZ06 is online now   Reply With Quote
Old 04-21-2009, 03:05 PM   #25
robvuk
CF Senior Member
robvuk's Avatar
Quote:
My theory comes from some experience in another related area. Back in 1969 a friend of mine had a new Roadrunner. It was popular in those days to jack up the rear of the muscle cars with airbags. He had installed them and kept breaking the shock mount where they were supporting the car. I saw this part first hand as I was asked to weld the broken parts for him. The leaf springs were no longer doing the job. We had to beef up the very thin structure at the top of the airbag to keep it from breaking repeatedly.
Old 04-21-2009, 06:30 PM   #26
Viper_Vette
CF Senior Member
Viper_Vette's Avatar
Quote:
Originally Posted by GOLD72 View Post
I am not at all concerned with this issue because it isn't an issue. GM engineered and sized this aluminum frame to flex within its endurance limits. And everything flexes including steel.
Aluminum frames are NOT suppose to flex at all. Remember that.
Viper_Vette is offline   Reply With Quote
Old 04-21-2009, 07:05 PM   #27
Fonzijr1964
CF Senior Member
Fonzijr1964's Avatar
There's a thread over in the ZR1 section about this same thing. Some guy is worried that if you use a Z06 or ZR1 as a DD that it's gonna fall apart. Here's my response from over there, and I'd give the same advice to the OP of this thread - don't ever fly in an airplane again if you're worried about aluminum breaking after a few flexes:
Bob
funny how that was my thread and I am in this one too
Fonzijr1964 is offline   Reply With Quote
Old 04-21-2009, 07:33 PM   #28
fiveodude
CF Senior Member
fiveodude's Avatar
Bob
But my aluminum Diet Coke can flexes and crumples badly so the Corvette frame must do the same.
fiveodude is offline   Reply With Quote
Old 04-21-2009, 07:56 PM   #29
robvuk
CF Senior Member
robvuk's Avatar
Quote:
EVERYTHING flexes. Even glass.
Old 04-21-2009, 08:20 PM   #30
Carnac
CF Senior Member
Carnac's Avatar
Send a message via AIM to Carnac
Dodge Prowlers were recalled for failing aluminum frames. Really pissed off some of the Prowler guys because dodge replaced the vehicle (no frame repairs), but made no allowance for any mods done (a lot of custom paint worth a lot of $). Aluminum must be engineered correctly to guard against stress risers and cracking. Steel is much more forgiving. Also, when a steel frame begins to fail (due to rust, damage, over stress) it fails gradually, but an aluminum structure will fail all at once.
Carnac is offline   Reply With Quote
Old 04-21-2009, 11:15 PM   #31
Maxx Schlick
CF Senior Member
Maxx Schlick's Avatar
Send a message via AIM to Maxx Schlick
They can't take the heat.
Maxx Schlick is offline   Reply With Quote
Old 04-22-2009, 12:13 AM   #32
VettedCandidate
CF Senior Member
VettedCandidate's Avatar
See...I was just hoping (knowing of course it wouldn't happen) that nobody would say anything unless they had problems with their Z06/ZR1 aluminum frame. That way, there would have been NO RESPONSES. See how that was supposed to work?!
VettedCandidate is offline   Reply With Quote
Old 04-22-2009, 10:50 AM   #33
fiveodude
CF Senior Member
fiveodude's Avatar
Quote:
Sorry, we have a hard time ignoring d-bags.
Old 04-22-2009, 05:48 PM   #34
Landru
CF Senior Member
Landru's Avatar
From your lips...
Landru is offline   Reply With Quote
Old 04-23-2009, 08:22 AM   #35
GOLD72
CF Senior Member
GOLD72's Avatar
You are clearly not an engineer. I am. You are wrong. Any part that takes a load (stress) will deflect (strain). Engineering terms for flex. Simple physics. The only thing to debate is how much deflection will occur. I believe GM has sized the frame cross sections internally to take the loads and the resulting strains imposed by the Z06.
__________________
GOLD72
1972 WB Coupe L48/TH400 - Sold
2001 QS Z06 - Sold
2006 VY Z06 - Sold
2007 MR Vert - NCM Delivery & Wife's Garage Queen
2010 Vanilla Latte CTS 3.6L Sport Wagon - Wife's DD
2011 AW ZR1 - NCM Delivery & Daily Beater
GOLD72 is offline   Reply With Quote
Old 04-23-2009, 08:24 AM   #36
GOLD72
CF Senior Member
GOLD72's Avatar
Exactly.
__________________
GOLD72
2001 QS Z06 - Sold
2006 VY Z06 - Sold
Old 04-23-2009, 10:22 AM   #37
Just Enough
CF Senior Member
This is true, I had my aluminum frame replaced with a glass one and I can still feel some flex. The cool thing is that I can see my fuel lines and torque tube from the side of the car.
Just Enough is offline   Reply With Quote
Old 04-23-2009, 10:56 AM   #38
teking
CF Senior Member
teking's Avatar
Send a message via AIM to teking Send a message via Skype™ to teking
Quote:
teking is offline   Reply With Quote
Old 04-23-2009, 01:00 PM   #39
fperra
CF Senior Member
fperra's Avatar
Let's see now, there are still DC-3's flying and the wings aren't falling off. So I think my ZO-6's frame will still be here in fine shape long after I'm turned into ashes.
fperra is offline   Reply With Quote
Old 04-23-2009, 02:24 PM   #40
avacorvette
CF Senior Member
avacorvette's Avatar
Location: Canonsburg home of Yenko Chevy (gone but not forgotten) Western PA
One E to another E
avacorvette is offline   Reply With Quote
Reload this Page Any Z06, ZR1 frame failures?
Tags
aluminum, bending, c6, coilovers, corvette, difference, fail, failure, flexing, frame, parts, penske, shocks, z06, zo6, zr1
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
10 Things GM Could Do To Make Corvette Its Halo Car Again Vette73 C6 Corvette General Discussion 23 07-14-2003 09:02 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
