C6 Corvette ZR1 & Z06General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
at the track we went 9.97@139 n/a 1st c6 z06 in the 9,s and did it with
a 6speed thanks carmen and dennis
sorry J you can be next
Congrates my man! We need some really good D/A around here for me to pull that off, and I think summer is here for us. But someone HAS to represent, might as well be u!
Congrats! I have followed your older posts but can't remember if you have any weight reduction done to the car? What is your raceweight?
it was 3200 prior to the new clutch that is lighter and the front skinnies
and a light weight racing battery and a few other little things
it should be around 3100 by now
Did you go with the aluminum flywheel/carbon clutch and how is the pedal effort compared to stock...my 09' leaves in the morning for the same package from the Docs...
it is the steel flywheel, it will be to the doctors the do the install
i killed the ram today (rip)
