[Z06] broken exh valve
happened to me!
I switch to stainless Steele as well. I also know a number of guys that switch to stainless Steele eventhough their exhaust valve were fine. That said, I'm not so sure it is that much better (if better at all?!?) than the sodium field stock valves.
The main advantage is that they will bend and not break under extreme circumstances (piston/valve contact).
that's what I've been told!
That's what my mechanic told me theoretically. But the end result will be the same. The stock stainless steal exhaust valve, sodium field & hollow stem is better performance wise cause of its lighter construction and with the sodium keeps it from heating up too much. But with the sodium filling it, it has a hollow stem which is not as strong as the solid stainless Steel valve. Thus the snapping. The solid stainless on the other hand is heavier & stronger but heats up more & could seize up and in turn could cause the same damage as a snap valve would. Who knows which is better? All I know is that sodium filled exhaust valve or stock valve was good to me until after we install the cam & double springs. IMHO, the upgraded springs were too strong for the stock valves. My .02. Who knows which one is better?
1 Post
