Corvette Forum
Go Back   Corvette Forum > C6 Corvette, 2005 - ???? > C6 Z06 Discussion
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C6 Z06 Discussion
General Z06 Corvette Discussion, LS7 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track Sponsored by
PFYC
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 03-18-2009, 03:53 AM   #1
blitzu
CF Senior Member
blitzu's Avatar
Default Nitto NT-05 Review
So I got the tires on the car last week when it was 30 degrees out. First impression was good. They rode smooth, and got almost better grip in 30 degree weather than my GY's ever did in the dead heat of summer.
Fast forward to today when it was 65 out and holy hell do these things stick like no other! I have slightly over 520 RWHP and these things grip and the front end lifts up like it never did before! It holds first gear better than I could have imagined, and it holds second flawlessly. Cornering is VERY stable and it holds strong. I was able to take a common 90 degree turn I go through each time I drive much quicker than I ever could with the GY's. This car is a totally new beast, and I found a new level of appreciation for it.
As for ride comfort they feel 10x's smoother than the GY's so I am very happy all around. I cannot wait to get this to the track! I am willing to bet these things will easily get me my 10 second slip. Only downside is that they do smell like horse crap and rubber for the first week... but it has been fading away. I am 150% satisfied with their performance and for the price I can't see how they can ever be beat.
BTW, I have the 275's in front.
blitzu is offline   Reply With Quote
Old 03-18-2009, 04:35 AM   #2
Randy@RaginRacin
Supporting Vendor
Randy@RaginRacin's Avatar
Thanks for the review.
Randy@RaginRacin is offline   Reply With Quote
Old 03-18-2009, 04:40 AM   #3
kumar75150
CF Senior Member
kumar75150's Avatar
Send a message via AIM to kumar75150 Send a message via Yahoo to kumar75150
good stuff
I will probably switch to them when my INVOs are done.
kumar75150 is offline   Reply With Quote
Old 03-18-2009, 05:12 AM   #4
blitzu
CF Senior Member
blitzu's Avatar
Thanks! These things stick like glue... I'm actually quite amazed and didn't expect this good of grip.
Old 03-18-2009, 07:49 AM   #5
Fast06Z06
CF Senior Member
Fast06Z06's Avatar
Awesome Im planning on buying my set today actually. What sizes did you get all the way around?
Fast06Z06 is offline   Reply With Quote
Old 03-18-2009, 11:09 AM   #6
toxin440
CF Senior Member
I'm on my Invo's as well - I will more than likely switch to these as well when my Invos' burn out due to their size being closer to the stock sizes.
Not that there is anything wrong with 345/35/19.... but i'd rather be matched than not.
toxin440 is offline   Reply With Quote
Old 03-18-2009, 11:19 AM   #7
GMuffley
CF Senior Member
Thanks for the report. It seems from your experience that they NT-05 tires turn in as quickly as the Goodyears. I presume they have stiffer sidewalls than the Invos?
GMuffley is offline   Reply With Quote
Old 03-18-2009, 11:42 AM   #8
Jasil
CF Senior Member
Jasil's Avatar
Sounds to good to be true, honestly
They stick better, quieter, better ride, and handle just as well or better?
Something has to give somewhere, but thanks for the review.
Jasil is offline   Reply With Quote
Old 03-18-2009, 11:53 AM   #9
COR Wheels
CF Senior Member
COR Wheels's Avatar
Great review!!
COR Wheels is offline   Reply With Quote
Old 03-18-2009, 12:07 PM   #10
Rez90
CF Senior Member
Rez90's Avatar
thanks for the great review.
Rez90 is offline   Reply With Quote
Old 03-18-2009, 03:46 PM   #11
usmc42
CF Senior Member
usmc42's Avatar
thanks for the review. Mine should be here friday although i went up one size front and back. I didn't even see stock sizes available in the rear? where'd u get em or did you go 1 up in the rear and stock in the front?
usmc42 is offline   Reply With Quote
Old 03-18-2009, 03:49 PM   #12
obzidian
CF Senior Member
St. Jude Donor '09
obzidian's Avatar
Why the 275 front? I thought the 285 front was the better match for the 335 rear?
obzidian is offline   Reply With Quote
Old 03-18-2009, 04:03 PM   #13
Evilness
CF Senior Member
Evilness's Avatar
Send a message via AIM to Evilness
Quote:
Personally i think if u go 285 the car looks funny because of the big sidewall of the 35 if it was a 285/30 it would look killer..
R.
Evilness is offline   Reply With Quote
Old 03-18-2009, 04:06 PM   #14
Dr.Ron
CF Senior Member
Dr.Ron's Avatar
Location: 2007 Nat'l Corvette Challenge 11.50 index Champ. New Jersey
How would you compare the sidewall stiffness compared to the GY's?
I had once tried MPS's & they felt like mush compared to the GY's on my 03 C5Z...
Ron
Dr.Ron is offline   Reply With Quote
Old 03-18-2009, 05:57 PM   #15
Dirty Howie
CF Senior Member
Dirty Howie's Avatar
Quote:
R.
How much bigger could the sidewall be??
Wouldn't it just fill up the wheel well a little more???
Can you explain or show some photos
DH
Dirty Howie is offline   Reply With Quote
Old 03-18-2009, 06:12 PM   #16
Phil_Le_Mans_Blue
CF Senior Member
Phil_Le_Mans_Blue's Avatar
Are these better than the INVOs?
Phil_Le_Mans_Blue is offline   Reply With Quote
Old 03-18-2009, 06:38 PM   #17
PewterFRC
CF Senior Member
Quote:
I'm torn between the two. I can't make up my mind!
PewterFRC is offline   Reply With Quote
Old 03-18-2009, 06:46 PM   #18
dvandentop
CF Senior Member
dvandentop's Avatar
now to see if i can kill the runcraps this summer
dvandentop is offline   Reply With Quote
Old 03-18-2009, 06:49 PM   #19
hpaddict
CF Senior Member
hpaddict's Avatar
R.
Not true, the 285 is a better match for the 335 and you will not notice the sidewall difference at all.
hpaddict is offline   Reply With Quote
Old 03-18-2009, 07:13 PM   #20
04_Z06_CE
CF Senior Member
04_Z06_CE's Avatar
Quote:
Mee 3..
Its almost time for me too and I just want the better Straight Line traction as well..
Cant seem to figure it out...
04_Z06_CE is offline   Reply With Quote
Reload this Page Nitto NT-05 Review
Tags
1994, advertised, auction, corvette, corvetteforum, hoosier, mpsc, nitto, nt05, r6, ratios, review, site, stock, tc
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
