Corvette Forum
Go Back   Corvette Forum > C6 Corvette, 2005 - ???? > C6 Z06 Discussion
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C6 Z06 Discussion
General Z06 Corvette Discussion, LS7 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track Sponsored by
PFYC
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 02-23-2009, 01:46 PM   #1
UR2SLO
CF Member
Default Got dynod stock numbers....freak???
i just got my car dynod a couple weeks ago at 8900miles, the car is stock and always seemed to pull strong (as a Z06 should).
After buying and installing a K&N intake on it it felt a little slower so i wanted to get a before and after dyno done to make sure i wasnt losing power with out having it tuned. To my surprise i was losing a tremendous amount of power in the midrange, and topend too. The guy performing the dyno said it felt almost as if it was detinating. Those numbers came out to 454rwhp and 380tq with a nasty midrange tq curve. we swapped out to the stock intake and the car run much better putting down 473rwhp and 438rwtq bone stock!
heres a pic of the dyno chart (scanner having problems):
Red is stock curves, blue is K&N.
and heres a vid of the dyno... at the end of these computer generated daily driver races....
http://user.streetfire.net/video/Str...yno_636148.htm
intake reinstall with tune soon to come
UR2SLO is offline   Reply With Quote
Old 02-23-2009, 01:58 PM   #2
Vindication
CF Senior Member
Send a message via AIM to Vindication Send a message via Yahoo to Vindication
great numbers for just a intake. I remember my car in stock trim put down 440 here in California and 431 in Michigan...
You got lucky....
__________________
W2W 427 LS7 Sleeved, LSW All Pro Heads with Jesel J2K Rockers with MoHawk Option , TTiX Z06 Twin Turbo kit, RPM Level 5 Transmission, RPM Z06 Differential, HKS EVC 6 Boost Controller, ECS Meth kit, Corsa 3 inch Catback and Mid Pipe, Auto Meter Nexus Gauges, HRE 897R 19/20 wheels. *707 RWHP at 10 psi, 904 rwhp 14.5 psi* FOR SALE!!!
Vindication is offline   Reply With Quote
Old 02-23-2009, 02:10 PM   #3
UR2SLO
CF Member
Quote:
You got lucky....
thats with stock intake on that i made 473whp the aftermarket intake killed my power for some reason so i put it back to stock
Old 02-23-2009, 02:10 PM   #4
Randy@DRM
Premium Supporting Vendor
Randy@DRM's Avatar
14.7 seems a bit lean.
Randy
Randy@DRM is online now   Reply With Quote
Old 02-23-2009, 02:12 PM   #5
UR2SLO
CF Member
oh the afr's werent being read we didnt stick that thing in the exhaust
Old 02-23-2009, 02:18 PM   #6
edcmat-l1
Supporting Vendor
edcmat-l1's Avatar
Responded to your other thread.
edcmat-l1 is offline   Reply With Quote
Old 02-23-2009, 05:13 PM   #7
Z0SLIK
CF Senior Member
Z0SLIK's Avatar
Good info!!
Z0SLIK is offline   Reply With Quote
Old 02-23-2009, 05:30 PM   #8
GaryZ06
CF Senior Member
Those are STD numbers you need SAE corrected numbers.
GaryZ06 is offline   Reply With Quote
Old 02-23-2009, 05:30 PM   #9
USMCFRC
CF Senior Member
USMCFRC's Avatar
What were the corrected numbers?
USMCFRC is offline   Reply With Quote
Old 02-23-2009, 08:09 PM   #10
evo8 MR
CF Senior Member
You got lucky....
Did you bother to read his post?, he clearly says that he lost power with the K&N intake.
evo8 MR is offline   Reply With Quote
Old 02-23-2009, 08:34 PM   #11
Fast06Z06
CF Senior Member
Fast06Z06's Avatar
Sounds like the car was leaning out some. Id put it back on like you said and have it tuned and fatten it up. I am certain it will put out atleast 10 more hp than what it is running right now with the stock intake on if not more. I picked up ALOT with just the KN. My car was 486 with just a KN and NO tuning.
Fast06Z06 is offline   Reply With Quote
Old 02-23-2009, 10:48 PM   #12
Scuba_Steve
CF Senior Member
Scuba_Steve's Avatar
That dyno graph is horrible. It's scaled differently for hp and trq which makes it very hard to read. Was the operator new to the dyno? Why wouldn't he log AFR's? Something was going on between those two runs besides an intake swap.
Scuba_Steve is offline   Reply With Quote
Old 02-26-2009, 01:52 AM   #13
Nuffsaid
Junior Member
Another positive response by Scuba. I think we all know what you need.
Nuffsaid is offline   Reply With Quote
Old 02-26-2009, 11:47 AM   #14
Scuba_Steve
CF Senior Member
Quote:
Enlighten me.
Do you honestly think his car picked up 75whp and 78wtrq in the mid range with an intake swap?
Quote:
Originally Posted by UR2SLO View Post
Now that I take a closer look I see the problem, neither pull is scaled correctly, the tach signal is way off because trq and hp don't cross at 5250 rpm as they should. That's why the numbers are all over the place.
Old 02-26-2009, 12:35 PM   #15
F1 CYA
CF Senior Member
F1 CYA's Avatar
Quote:
Can you tell us the corrected #?
F1 CYA is offline   Reply With Quote
Old 02-26-2009, 12:48 PM   #16
BubbaDuss
CF Senior Member
BubbaDuss's Avatar
Quote:
Originally Posted by Scuba_Steve View Post
Enlighten me.
HP is scaled on the left, TQ is scaled on the right, hard to visualize where they would cross.
second, he didn't pick up 75 HP with an intake, he lost 75 HP with an intake.
the AFR is bogus.
who uses SAE numbers anyway?
BubbaDuss is offline   Reply With Quote
Old 02-26-2009, 04:43 PM   #17
Scuba_Steve
CF Senior Member
the AFR is bogus.
So you really believe he lost 75whp with an aftermarket intake?
Look at the RPM on the bottom, way off. HP and TRQ must cross at 5250, in his graph they do not, the graph is wrong and pretty much useless information.
Old 02-26-2009, 07:28 PM   #18
RichieRichZ06
Supporting Vendor
St. Jude Donor '08
RichieRichZ06's Avatar
Location: Supporting the Corvette Community at Abel Chevrolet in Rio Vista, CA 707-374-6317 Ext.128
If you look at the scale on each side, they do actually measure the same at 5,250, just the lines do not intersect there. It is just waaaaaaaay confusing looking because HP and TQ are not on the same scale. It is at about 357 on the blue lines and about 435 on the red lines, right?
RichieRichZ06 is offline   Reply With Quote
Reload this Page Got dynod stock numbers....freak???
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
