Corvette Forum
Go Back   Corvette Forum > C6 Corvette, 2005 - ???? > C6 Z06 Discussion
New! Use your Facebook to securely log into this site, click logo to login
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ Photo AlbumsGarage
C6 Z06 Discussion
General Z06 Corvette Discussion, LS7 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track Sponsored by
PFYC
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 01-21-2009, 11:55 PM   #1
dpracing
CF Senior Member
dpracing's Avatar
Location: 11.13 @ 128.68 Bone stock on non stock tires.
Default **11.13 @ 128.68 new personal best **
Went to Palm beach intl raceway tonight and had some favorable weather finally.
Track prep was excellent. Air was great, about 45 degrees. Car is a 09 3LZ bone stock on drag radials. Used many of rangers recommendations
and as always they work.
I made 7 passes:
11.13 @ 128.68
11.20 @ 128.01
11.21 @ 127.87
11.22 @ 128.84
11.26 @ 128.10
11.32 @ 127.97
11.45 @ 127.70
I felt the car fall down just a hair on the 1-2 2-3 shifts probably from shifting a little aggressive. Torque management is a bitch. But overall I am very happy. The mph is outrageous to me at 128.84, It went 101 mph in the 1/8th a few times.
Need to work on the launches, best 60' was a 1.800 on the 11.13 pass.
I need a Dr. Ron launch (1.6XX) and I probably could have gone 10.90, or better. Oh well, we shall see in the future.
http://i243.photobucket.com/albums/f...6/timeslip.jpg
dpracing is offline   Reply With Quote
Old 01-21-2009, 11:57 PM   #2
C5 Frank
CF Senior Member
C5 Frank's Avatar
Great driving!!!! That is one fast '09!!!
C5 Frank is offline   Reply With Quote
Old 01-21-2009, 11:59 PM   #3
dpracing
CF Senior Member
dpracing's Avatar
Quote:
Thanks Frank, your "Lightweight" '06 did pretty well too
Old 01-22-2009, 05:06 AM   #4
Bills Z06
CF Senior Member
St. Jude Donor '07-'08-'09-'10
Bills Z06's Avatar
Congrats! Great numbers!
Bills Z06 is offline   Reply With Quote
Old 01-22-2009, 05:16 AM   #5
NHRA95
CF Senior Member
NHRA95's Avatar
Imagine what it would run removing TM with a tune and CAI? Great numbers!
NHRA95 is offline   Reply With Quote
Old 01-22-2009, 07:57 AM   #6
nzk
CF Senior Member
nzk's Avatar
those are amazing times! what are ur launch techniques?
nzk is offline   Reply With Quote
Old 01-22-2009, 09:14 AM   #7
extents
CF Senior Member
I made 7 passes:
11.13 @ 128.68
11.20 @ 128.01
11.21 @ 127.87
11.22 @ 128.84
11.26 @ 128.10
11.32 @ 127.97
11.45 @ 127.70
Those are great runs! You did well. I hope when I hit the track I can do that well. Yes, there are some members here that can drive! JFurman, Walterm, Dr. Ron... I've seen posts from these guys and I don't know how they do it. Nice work.
extents is offline   Reply With Quote
Old 01-22-2009, 09:31 AM   #8
dpracing
CF Senior Member
dpracing's Avatar
Quote:
Launch techincs were basically 3500- 3800 rpm and a quick to mild slip of the clutch, the car always bogged, it is so frustrating leaving the line with the C6Z.
Old 01-22-2009, 11:23 AM   #9
Z06Norway
CF Senior Member
Z06Norway's Avatar
Default wow, great trap speed
09 bone stock and 128 mph is amazing, makes alot more Hp than advertised :-)
Rune
Z06Norway is offline   Reply With Quote
Old 01-22-2009, 11:45 AM   #10
dpracing
CF Senior Member
dpracing's Avatar
Quote:
Rune
Thanks alot Rune,
I was very impressed with it myself.
There were alot of CF members there last night also.
I have approx 80 passes in 2 different C6Z's. I would imagine this is also the reason for extracting the most from the car.
I plan on going again on friday. I really want a 10.XX pass.
Old 01-22-2009, 05:34 PM   #11
Myhardtop
Supporting Vendor
Myhardtop's Avatar
Thanks alot Rune,
Those are some great numbers my friend.
You want some 10.XX, heck, you are there. Try these true and tried methods combined with your practices if not already:
Ice down your intake manifold between runs
Move driver seat to the up right position and as close to the pedals as possible so you get good leverage.
Bring a bottle of new clutch fluid for replacement (or change at home)
Pump up front tires between 45 and 50 psi
Take down rear tires between 18 and 22 psi
Not too much gas in the tank (¼ is plenty)
Speed shift into 2nd and it traction is available, powershift into 3rd and into 4th. If you’re not too crazy about powershifting then shift as fast as you can. Great traction should NOT trigger the TM gods as much as if you were to spin too much.
I know the stock clutch is a pain but try cutting some low 1.70’s or better and then see what happens!!! I tell ya what will happen, you will be running 10’s and be asked to leave but not before having a group of guys around you and your car seeing your set up and asking plenty of question…which is cool with me.
Thanks,
Carlos
__________________
www.vette-air.com
Myhardtop is offline   Reply With Quote
Old 01-22-2009, 07:43 PM   #12
dpracing
CF Senior Member
dpracing's Avatar
Thanks,
Carlos
Thanks Carlos
Old 01-22-2009, 08:23 PM   #13
C5 Frank
CF Senior Member
C5 Frank's Avatar
You going again tomorrow night?
Old 01-22-2009, 08:33 PM   #14
'06 Quicksilver Z06
CF Senior Member
'06 Quicksilver Z06's Avatar
I made 7 passes:
11.13 @ 128.68
11.20 @ 128.01
11.21 @ 127.87
11.22 @ 128.84
11.26 @ 128.10
11.32 @ 127.97
11.45 @ 127.70
Terrific.
Post it up into "The C6 Z06 Fast List" thread and I will add it to the listing.
Congrats on a fantastic run.
'06 Quicksilver Z06 is offline   Reply With Quote
Old 01-22-2009, 08:37 PM   #15
383vett
CF Senior Member
383vett's Avatar
Very, very, very impressive numbers. Your car makes a ton of hp. Also the fact with all your time runs, you didn't have one bad run. I seem to miss the 2-3 shift or spin or bog or break every few runs with my 08. Good job. Any wheelhop? Probably not with the drag radials.
383vett is online now   Reply With Quote
Old 01-22-2009, 08:43 PM   #16
dpracing
CF Senior Member
dpracing's Avatar
Quote:
Thanks 383vett,
No wheel hop, Just the bog was terrible, I think I was invoking torque management w/ to much clutch too fast.
Old 01-22-2009, 08:54 PM   #17
NASTY ZO6
CF Senior Member
NASTY ZO6's Avatar
Congrats!!! How is the new track now that it is all concrete?
NASTY ZO6 is offline   Reply With Quote
Old 01-22-2009, 08:57 PM   #18
dpracing
CF Senior Member
dpracing's Avatar
Quote:
Thanks!
The track is great. There were some pro cars testing there that day so the prep was fabulous.
Old 01-22-2009, 08:59 PM   #19
dpracing
CF Senior Member
dpracing's Avatar
FRANKIE!
I think I am going to go. The 10.XX is all up in my head.
The launch is just givin' me a brain hemorage. I have to conquer!
Old 01-22-2009, 09:38 PM   #20
C5 Frank
CF Senior Member
C5 Frank's Avatar
FRANKIE!
You.... I dont want to hear it. I finally get a 1.88 and my best ET on my last run of the night! No question I would have gotten into the 20s if I could have cut that 60ft a little earlier in the night! Goodluck if you go. I cant make it... but I will be with you in spirit!
PS To think when I met you, you were running 12.10s at 119 with your '07Z.... Now you are the man....
I on the other hand was running 11.50s then.... and still run mainly 11.50s...LOL
Reload this Page **11.13 @ 128.68 new personal best **
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertise Here - Contact Us - Corvette Enthusiast Discussion Forum - Archive -
Top
Powered by vBulletin
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
