C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] C6 Z06 Cabin air filter?
Old 01-13-2009, 08:51 PM
curvesman
curvesman's Avatar
C2 of the Year Finalist - Unmodified 2020
Default C6 Z06 Cabin air filter?
I saw a thread on the C6 Corvettes and the cabin filter is located behind the Battery in the Engine compartment.
Any body know where its located on the Z06, being the battery is in the trunk. Its also a good reminder to all.( If there is one).
Thanks in advance!
Old 01-13-2009, 09:05 PM
Stage Runner
Stage Runner's Avatar
Thanks in advance!
Same location as C6, passenger side upper firewall adjacent canister. Un-snap clip, open hatch and remove filter. Note flow orientation upon removal.
Old 01-13-2009, 09:14 PM
Madsen
Madsen's Avatar
Correct, correct and mine was dirty after 15k
easy to change and best when the car is not hot.
Old 01-13-2009, 09:42 PM
DSteck
DSteck's Avatar
I found this inadvertently, because my cam shook the clips loose. A strong odor tipped me off to check the engine bay!
As stated above, it's in the same spot as a normal C6. It's in plain view, and nothing is in the way.
Old 01-14-2009, 07:10 AM
GOLD72
GOLD72's Avatar
Received 1,106 Likes on 718 Posts
After 30k miles, I pulled my for inspection and found that it only needed cleaning with a shop vac. I saw no reason to buy a new one. The GM filter appears to be a very gauzy pleated paper thing and fairly substantial in its tolerance for being vacuumed. I would recommend inspection prior to deciding on replacement. It's easily removed from the Z06 firewall.
Old 01-14-2009, 11:21 AM
ipmtim
ipmtim's Avatar
Cruise-In VIII Veteran
St. Jude Donor '06
Good info, never thought to check it.
Tim
Old 01-14-2009, 06:24 PM
curvesman
curvesman's Avatar
Thanks to all, She is put away for the winter so will check it as soon as all the white stuff is gone.
To C6 Z06 Cabin air filter?
Quick Reply: [Z06] C6 Z06 Cabin air filter?
