[Z06] I came sooooo close to the 10's VIDEO
I attended another rental day at MIR Wednesday December 3rd. CF member Siffert(Gary) got in touch with me about a week earlier and asked if I was interested in going. He made the trek from Ohio 6 hours away hoping to take advantage of the good Maryland air and Traction. There was 7 or 8 of us there which made for another great day. On my 3rd pass of the day I ran my personal best to date. 11.027@125.66. When I took off I looked up at the board and saw that I cut a 1.74 60ft and thought I had a real chance to hit the 10's. So damn close but no cigar. If it weren't for the slight headwind we had the majority of the day I think it would have been there but I ain't complaining, there's always next year. I'm quite happy with the results. Here's the video (Its high resolution):
http://www.youtube.com/watch?v=sdW9EgHjDpA
For those that were there. I'll get your videos up ASAP. My computer at home is all messed up. This video took over 2 hours for me to upload so it might be a few days.
The launch sounds terrific and your shifts and shift points sound even better than on any of your other videos.
You've improved tremendously from where you were earlier in the year and now have the results to show you are one of the best drivers out there. You should be very proud of your accomplishment and know it couldn't have happened to a better guy. Your hard work has paid off big time. Congrats on putting it all together.
Was great meeting you and working with you in 2008 and looking forward to getting together in 2009.
Wow Mike - That is just awesome. Running 11.02 on the stock EMT's with just an exhaust is incredible.
The next rental I know about I'll let you know.
How about a boltons w/ stock tires section.
[Quote] Wow, that is incredible. 11.02 with nothing but a catback exhaust.
Walter as good as your driving that car, I would put the stock exhausts back on that car and go for the top of the stock list! Those exhaust might make more noise but the car might run just as good if not better 1/4 mile times with the factory exhuasts. I have seen that be the case in some of my other cars.
[QUOTE=jamie furman;1568105307]
I am going to put the stock exhaust back on before next fall. Top 3 would be just fine. That 10 sec barrier seems to be a tough one to get.You have to be on your game on the right day. You were. I'd like to be.
When I changed to the Corsas I noticed the pipe is 3" all the way into the mufflers. On the stock mufflers the pipe steps down to 2.5" just before it goes into the mufflers. What effect it has?? Probably not much either way.
Be glad to re-dyno my car at the same time if you decide to do this.
Mike - Was thinking you might want to dyno your car before you change your exhaust. If you take your car to Tony's Corvette, you can compare to the dyno I had done there with my car and see if you have any performance benefit from the Corsa exhaust and 3" pipes. Then at least you'd have a baseline to know where you are currently and make your decision based on this.
I'd be interested to see if the graphs are any different but I think 08's make more power so there is no comparison. its a controlled enviroment there isn't it. If so there would be no need to re dyno yours. If I get a few bucks extra I will before I switch them out and we'll see. My guess is no more than a 3 or 4 HP or TQ gain anywhere throughout the curve if anything at all. Who knows mabey Corsas add 50 HP and that's why I ran an 11.02.
They have a SuperFlow Dyno and really nice setup - very accurate and repeatable under a variety of conditions. It's our cars that aren't quite so consistent. Just like at the track, you've got to keep the IAT temps and Coolant temps down or you wont see the max your car is capable of.
Also keep in mind there is no dyno in the world that can adjust for the differences the LS7 PCM makes to the tune under various conditions.
IMO thats exactly why he trapped higher, because when your tires are hazing just a little bit and then start to hook the car has more momentum when they bite and that results in higher trap speeds, exactly what you saw in some of those videos posted of my car running a couple of weeks ago. They were the best mph's I had ever run as the tires were hazing the first 150', but the ets weren't there because my 60' was 1 to 2 tenths off my best. Dr Ron is the 60' King but his mph is always one of the slower ones on the top of the fast list. His 60' is the best, but I bet if there was a 200' mph marker his mph wouldn't be as fast as similar cars with slower 60' times.
