C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Checkout our new Fan Control Switch....
Old 04-25-2013, 12:46 AM
  #41
db2xpert
db2xpert's Avatar
Been using this for a couple of years.
Love it....
Old 10-21-2013, 05:05 PM
  #42
erikszr1
erikszr1's Avatar
ive had mine for months, works very well.
Old 10-21-2013, 07:24 PM
  #43
southerncarparts
Supporting Vendor
southerncarparts's Avatar
St. Jude Donor '06-'07, '13, '15
Thanks again sir!
Old 10-28-2013, 03:20 AM
  #44
wolf8218
wolf8218's Avatar
What's the difference between the new and old version?
Old 10-28-2013, 07:23 AM
  #45
erikszr1
erikszr1's Avatar
Not sure if its any different, either way get one
Old 10-28-2013, 07:49 AM
  #46
wolf8218
wolf8218's Avatar
Definitely
Is there anything else required for the track? Larger radiator?
Old 10-28-2013, 11:12 PM
  #47
wjnjr
wjnjr's Avatar
The old version is like the picture above. The control module is in between the two big connectors and lives right next to the radiator. There were some problems with the modules failing due to heat, so the new version addresses this by moving the module inside the car. Make sure to get the new version.
Here's the manufacturer's website: http://www.casperselectronics.com/st...oducts_id=1473
I've been using one of these for three years now and like it a lot. It really works to keep the temp down in Houston traffic in the summer. The key is to turn the fan on high before the temp starts to rise. For example, I'll turn the fan on high as I exit the freeway, well before the first light. Water temp in traffic will stay around 210 now instead of 225+ like before.
When you do the installation, pay close attention to your connectors as you may find some heat damage. I did, it's pretty common but fortunately not a big deal to fix. Casper's sells the terminals to rebuild them or the complete connector if you need it.
Old 12-07-2013, 01:10 AM
  #48
Mike.D
Mike.D's Avatar
i like it.. Ordered
Old 12-08-2013, 04:08 PM
  #49
southerncarparts
Supporting Vendor
Originally Posted by Mike.D
i like it.. Ordered
Thank you for the order.
Old 12-08-2013, 06:43 PM
  #50
Mike.D
Mike.D's Avatar
where does the wiring loom go from the engine bay to the inside? any pictures?
Old 12-08-2013, 10:55 PM
  #51
dovervold
dovervold's Avatar
Old 01-01-2014, 03:58 PM
  #52
Mike.D
Mike.D's Avatar
Installed, fan speeds do not work. I only have one speed. Pm'd op weeks ago with no response.
Old 01-03-2014, 01:33 AM
  #53
db2xpert
db2xpert's Avatar
Maybe one of the connectors if of the switch?
Had mine for a few yrs. Great unit.
If no fast answer to PM use the telephone
Old 03-08-2014, 02:51 AM
  #54
Blk 08 C6
Blk 08 C6's Avatar
ordered.
Old 03-09-2014, 09:05 AM
  #55
bjones7131
bjones7131's Avatar
will this work for a c5
Old 03-10-2014, 09:29 PM
  #56
szaro1
szaro1's Avatar
was having difficulty last summer with my h/c z06 running hot in the 85/90 degree weather when driving around town hitting stop lights constantly. When driving around on days like this is it possible to just keep it on either on low or high during the whole duration of the drive? Is it bad to do this?
Old 04-13-2014, 08:07 PM
  #57
southerncarparts
Supporting Vendor
Sorry. It won't.
To Checkout our new Fan Control Switch....
Old 04-20-2014, 05:08 PM
  #58
ProEFI
Supremacy 1 car at a time
Support Corvetteforum!
ProEFI's Avatar
had the same kit on mine and, I think it's useless with the temperature here it's goes up to 55 degrees XD Hellbox
Old 05-30-2014, 10:40 PM
  #59
southerncarparts
Supporting Vendor
Just launched....
Take complete control of your C6, Z06, or ZR1 coolant fan with our new Corvette C6 Fan Control Switch
This brand new Plug-And-Play control module installs under the hood, at the fan connector, and is designed to manually control the PWM coolant fan found on the 2005-2009 C6, Z06 and ZR1 Corvette. When the need arises to manually cool the radiator down, this module gives you complete control (high, low, and normal) of the fan with the simple flick of a switch. This kit can be installed in less then one hour, once you decide on where you want to place the control switch. This switch matches the style and look of cockpit switches used on all the C6 Corvettes.
Comes with easy to follow installation instructions.
Ordering info below.
David
Old 05-31-2014, 11:17 PM
  #60
rbaz06
rbaz06's Avatar
OP, your post indicates applicable year through 09. Mine is '12 Z. Got anything that would work for this application?
Looks like a great product.
Many thanks
Quick Reply: [Z06] Checkout our new Fan Control Switch....
