C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] 2008 Z06 may be a flaw in some tranny's
Old 09-20-2008, 10:43 AM
bmastroman
Cruising
bmastroman's Avatar
Default 2008 Z06 may be a flaw in some tranny's
GM is playing hardball with a potential flaw with the tremac T6060 MM6 transmission. To make a long story short my new Z purchased in May 2008 had that so called cold grind shifting into second. Brought car to dealer and had syncro's and 2nd gear replaced. Machanic saw what he called an unusual metal burn where the syncro's seat. 400 miles later same grinding problem especially with shifts at +3500 rps. Tranny taken apart again, same exact problem same exact metal burn. I demanded a new tranny. Dealer recommeded the ball go to GM's court because of what they believed was a potential flaw. This dealer is not the dealer I purchased this vehicle from. GM wanted it fixed again before they would even concider a new tranny. New syncros and gear was sent to dealer. Took 3 week to get. Dealer said parts were out of stock and GM was getting a new vender. Part came in two days ago and were rusted in the package upon delivery. Dealer said he would not put those parts in the tranny, they were flawed. I am still waiting for new parts. Between both repair attempts the car has been apart sitting in the shop over 5 weeks. My many complaints to GM have been a waste of time. The warantee complaint center is handled in Argentina and they do nothing but try to blow smoke up you *** while they sheild GM of any direct contact. I believe that there is a milling problem with the syncros or the gear they seat on and GM may being trying to delay any potential recalls of the T6060. A lemon law attorney has taken on this case even though this has not yet been the third repair attempt to qualify at no cost to me. Car only has 2,000 miles. Those of you 08 Z owners who have 2nd gear grind problems who have been told it is because the tranny needs to be warmed up may have the same flaw my Z has. GM CUSTOMER SERVICE is horrible.
Old 09-20-2008, 11:08 AM
USMCFRC
USMCFRC's Avatar
Sorry to here about your issues with the "T6060". I have a 08Z and have no grinding or issues with the tranny. I hope this is not a production flaw with the T6060. Some seem to have this issue, and some not.
Old 09-20-2008, 11:11 AM
jpcourt
jpcourt's Avatar
Good luck with everything, keep us posted on your progress.
Old 09-20-2008, 11:23 AM
'06 Quicksilver Z06
'06 Quicksilver Z06's Avatar
Originally Posted by bmastroman
GM is playing hardball with a potential flaw with the tremac T6040 MM6 transmission. To make a long story short my new Z purchased in May 2008 had that so called cold grind shifting into second. Brought car to dealer and had syncro's and 2nd gear replaced. Machanic saw what he called an unusual metal burn where the syncro's seat. 400 miles later same grinding problem especially with shifts at +3500 rps. Tranny taken apart again, same exact problem same exact metal burn. I demanded a new tranny. Dealer recommeded the ball go to GM's court because of what they believed was a potential flaw. This dealer is not the dealer I purchased this vehicle from. GM wanted it fixed again before they would even concider a new tranny. New syncros and gear was sent to dealer. Took 3 week to get. Dealer said parts were out of stock and GM was getting a new vender. Part came in two days ago and were rusted in the package upon delivery. Dealer said he would not put those parts in the tranny, they were flawed. I am still waiting for new parts. Between both repair attempts the car has been apart sitting in the shop over 5 weeks. My many complaints to GM have been a waste of time. The warantee complaint center is handled in Argentina and they do nothing but try to blow smoke up you *** whilemthey sheild GM of any direct contact. I believe that there is a milling problem with the syncros or the gear they seat on and GM may being trying to delay any potential recalls of the T6040. A lemon law attorney has taken on this case even though this has not yet been the third repair attempt to qualify at no cost to me. Call only has 2,000 miles. Those of you 08 Z owners who have 2nd gear grind problems who have been told it is because the tranny needs to be warmed up may have the same flaw my Z has. GM CUSTOMER SERVICE is horrible.
Might be on to something.
This is another '08 with a transmission problem. 3000 miles 4 months old.
http://forums.corvetteforum.com/show....php?t=2136663
Old 09-20-2008, 12:16 PM
carcrazyandbroke
carcrazyandbroke's Avatar
I called it what it is early on (POS) and got flamed. I do not try speed shifts anymore because of missing shifts from 1st to 2nd. Oh yea, I know, the transmission does not miss shifts the driver does. Give me a break "Air Heads"
Old 09-20-2008, 12:22 PM
joe11204
Procharged F1X 7.18 @ 197
Support Corvetteforum!
joe11204's Avatar
St. Jude Donor '09-'10-'11
I know exactly what your going through.
Old 09-20-2008, 12:47 PM
Luweegy
Luweegy's Avatar
I've got an 08 that grinds going into 2nd gear at any rpm and any temp.Built 12 07,2100 miles and it has done it scince day 1.Just been waiting for a tsb so I don't have to go thru all the run arounds.
Old 09-20-2008, 12:49 PM
Red C6 Z06
Red C6 Z06's Avatar
St. Jude Donor '05 '09
I thought your problem was in 1st and 5th Joe!?
I'm now glad I bought an '07
Old 09-20-2008, 12:54 PM
'06 Quicksilver Z06
Well, I'm glad mine is an '06 with the old, tested and true T56 transmission in it. But I am still upset to hear that this problem has happened in the '08s with the TR6060.
People with the base '08 C6s have described similar problems with the TR6060 as well.
Old 09-20-2008, 01:04 PM
joe11204
joe11204's Avatar
Thomas your are correct, my problem is with 1st and 5th gear. However, I find it relevant that he has been waiting for parts as long as I have. Keep in mind I had some sort of minor "grind" since I took delivery. But all I heard and read was that this condition was inherent to the 6060 when cold. Believe me I was cringing at the thought of having a dealer tear open the trans, but I had no choice, it's broken.
Old 09-20-2008, 01:29 PM
Keyser Soze
Keyser Soze's Avatar
I've got the grind in 2nd and 3rd, but only when it's cold. After the car warms up the problem is gone.
Old 09-20-2008, 02:36 PM
QbnSuperman
QbnSuperman's Avatar
wow man, good luck. I hope the general pulls through.
I have an 08 Z with no grind thankfully.
Old 09-20-2008, 02:38 PM
RoHo
RoHo's Avatar
I have an 08 that I can red line in the first 4 gears and have never had a problem what so ever, so it's not all of them.
Keep us informed as to the final fix.
Old 09-20-2008, 02:41 PM
50vette
50vette's Avatar
Good LUCK!!
Old 09-20-2008, 07:32 PM
Finger
Finger's Avatar
I have the same problem when cold but goes away after it gets warm. 2008 Z06 500 miles.
Old 09-20-2008, 07:40 PM
OregonC6
OregonC6's Avatar
Argentina? Good grief. That's a new one. Making calls to companies today is like a trip around the world.
Old 09-20-2008, 08:30 PM
LT5 John
LT5 John's Avatar
I have an 08 Z06, no problems yet...However, only a couple of hundred miles on the car?...
To 2008 Z06 may be a flaw in some tranny's
Old 09-20-2008, 08:40 PM
TAILWAG
TAILWAG's Avatar
I have an 08' with 2,500 miles on the clock. I have yet to experience ANY tranny issues and she is driven hard. I do know however of 2 other 08' Z owners in the area that have 08's and ALL 3 of them have been in for some sort of synchro/clutch/tranny problem - all of them have 4,000 miles or less...yikes.
Old 09-20-2008, 11:09 PM
gotjuice?
gotjuice?'s Avatar
St. Jude Donor '13
Same for me. Still trying to monitor the situation to isolate problem.
Old 09-20-2008, 11:14 PM
AreOhBeeC6Z
AreOhBeeC6Z's Avatar
I had a 08 C6 with the new manual trans and had three total transmissions in the car under 2000 miles, I had the car bought back about a month and a half ago.
Quick Reply: [Z06] 2008 Z06 may be a flaw in some tranny's
