C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] A&A Frame Savers on a Z???
Old 09-10-2008, 03:20 AM
EmilT
EmilT's Avatar
Default A&A Frame Savers on a Z???
I had a C5 and installed the A&A Frame Savers to protect the rocker panels, but they also made it easy to slide a jack with a pad under the frame rail for quick lifting. It appears that A&A offers them for the C6. I would have no qualms about using them on the steel frame C6, but am a little leary of using them on the aluminum frame. I do not even know if they fit the aluminum frame. Has anyone used these on their C6-Z06?
http://www.aacorvette.com/index.php?...products_id=91
Old 09-10-2008, 07:22 AM
gotjuice?
Support Corvetteforum!
gotjuice?'s Avatar
St. Jude Donor '13
I made a set for my Z. I have not had a chance to install. The lower frame is not a smooth as the normal Vette. I hope it is just paint runs. I will find out in a couple of weeks.
Old 09-10-2008, 09:31 AM
TRR
TRR's Avatar
I bought some frame savers for my 07 C6 and took them off when I sold it. When I went to put them on my Z06 they would not fit. There are some welds on the frame that prevent you from screwing them on. I don't know if anyone makes them for the Z06 or not, but I have a pair for the C6 if anyone wants them.
TRR
Old 09-10-2008, 01:32 PM
04_Z06_CE
04_Z06_CE's Avatar
I have them(A&A) on my 08Z
Old 09-12-2008, 01:32 PM
0Steve@AandACorvette
Former Vendor
Steve@AandACorvette's Avatar
Location: Oxnard SoCal www.aacorvette.com www.superchargersuperstore.com
The rocker rails won't fit on the new Z, as TRR said, there are some welds that are not on the C6 base models.
The frame savers will fit all the cars.
To A&A Frame Savers on a Z???
Quick Reply: [Z06] A&A Frame Savers on a Z???
