Corvette Forum
Go Back   Corvette Forum > C6 Corvette, 2005 - ???? > C6 Z06 Discussion
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C6 Z06 Discussion
General Z06 Corvette Discussion, LS7 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track Sponsored by
PFYC
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Closed Thread
Old 05-25-2008, 03:44 PM   #1
Just J
Wizard of Odd.
Cruise-In Photographer
CI 1, 2, 7, 8, 9, 10 Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Support Corvetteforum!
Just J's Avatar
Default Weird (aftermarket) suspension failure.
Cruise-In attendees and followers are probably already aware that I had a significant suspension failure on my Z06 in Bowling Green.
There was a 6x6 or 8x8 piece of lumber in the road. Because of oncoming traffic, I couldn't move over far enough to miss it completely. There's not a mark on my bumper, so it appears that I hit it with the Gurney lip and the little bit of tire that sticks out. The impact punched out the coil-over mount but, as near as can figure (mechanics will be looking at it after the holiday) there isn't any other damage. (Pictures below.) The wheel has no scratches, dents or dings, and the tire is still holding normal pressure.
Since this is the first time I've banged up a Corvette, I'm looking for commentary on things to be sure to check for during the repair process - what little details need special attention to be sure the car gets back to factory standard condition, and where will it never make it back?
FWIW, it's a complete Pfadt setup - coilovers, sways, camber kit, and bushings.
Just J is offline
Old 05-25-2008, 03:49 PM   #2
camaross305
CF Senior Member
camaross305's Avatar
Send a message via AIM to camaross305
wow that sucks...glad iy didnt mess anything else up....I dont think you'll really be able to tell anything else until you get it fixed....then youll be able to tell what else happened.....I was ran off the road in my camaro ss a few years ago...had a set of aftermarket wheels and it was lowered. I got cut off and nailed a 6inch high curb....completely snaped 2 rims.....didnt do any other damaged though. I was really suprised.....so you never know
camaross305 is offline
Old 05-25-2008, 04:02 PM   #3
RC45
CF Senior Member
RC45's Avatar
I recall a number of folks asking about the rumoured weakness in the shock mount area... but they were chased off as fear mongers and nay-sayers.
I guess the upper shock mount is a weak point in the Vette chassis, since it is designed for transverse leaf springs... not coil springs.
RC45 is offline
Old 05-25-2008, 04:21 PM   #4
jamsvet
CF Senior Member
jamsvet's Avatar
Sure makes me think twice before going with coilovers.
jamsvet is offline
Old 05-25-2008, 04:24 PM   #5
C6400hp
CF Senior Member
C6400hp's Avatar
Location: DFW This user does not support or recommend the product or service displayed in the ad to the right
Wow, That right there is proof that is hard to deny. I wonder if the same would have happened with the steel frame of the standard C6? It looks like you can see the piece of aluminum frame ear punched right out inside the upper mount?
C6400hp is offline
Old 05-25-2008, 04:29 PM   #6
WFO
CF Senior Member
WFO's Avatar
Coilovers had absolutely nothing to do with this. The driver drove over a friggin log the size of a 6x6 or an 8x8.
WFO is offline
Old 05-25-2008, 04:40 PM   #7
RC45
CF Senior Member
RC45's Avatar
Quote:
Hmm - coil overs had nothing to do with this?
So in your opinion, the forces acting on the upper shock mount are no more with a coil over setup than a transverse leaf setup while driving over an 8x8 log?
I would rather say that it is possible the use of a coil over contributed to this failure - afterall, we really dont know do we?
Anyway - there were a number of comments from supposed GM source about the weaker aluminium upper shock mounts.
*shrug*
RC45 is offline
Old 05-25-2008, 04:42 PM   #8
C6400hp
CF Senior Member
C6400hp's Avatar
So you believe if he had hit the same thing with stock suspension that the factory shock would have punched through/sheared off the the upper shock mount?
C6400hp is offline
Old 05-25-2008, 04:43 PM   #9
jamsvet
CF Senior Member
jamsvet's Avatar
I realize that he drove over a railroad tie sized piece of lumber. What I would worry about would be the GM designing that went into the shock mounting point wasn't spec'd for a coil over setup. The lumber caused a sharp impact leading to catastrophic failure. Would repeated track days cause the upper shock mounts to distort or metal fatigue?
jamsvet is offline
Old 05-25-2008, 04:49 PM   #10
RC45
CF Senior Member
RC45's Avatar
Quote:
This was the point made by some folks who spoke about upper shock mount strengthening on the aluminium chassis.
I seem to recall this discussion happening at the time the C6 Z chassis was being tossed around as a possible race solution.
RC45 is offline
Old 05-25-2008, 05:03 PM   #11
WFO
CF Senior Member
WFO's Avatar
Quote:
Or possibly worse my friend..
Why do we argue over this crap?
Drive over a 6"-8" friggen log and you should expect some pretty good damage to an expensive, highly computerized, precision light weight sports car like a Corvette.
Moral of the story: Drive your truck over crap like this...then, hold your stones. Otherwise give yourself plenty enough room between vehicles to make corrections, braking and otherwise. Continue daily to dodge life's "unforunate incidence bullets" as they get thrown at you and hope for the best.
Look at the structural damage incidence rate for coilover users, not very common if at all.
This is just arm-chair quarterbacking.
WFO is offline
Old 05-25-2008, 05:13 PM   #12
'06 Quicksilver Z06
CF Senior Member
'06 Quicksilver Z06's Avatar
First of all thank goodness he is alright because this could have caused an accident.
Secondly, he did indeed drive over a log sized piece of wood. You would expect damage after that, however, is it reasonable to expect this much damage?
Dang, a Katech Z too. Wonder what the repair will involve.
'06 Quicksilver Z06 is offline
Old 05-25-2008, 05:15 PM   #13
gonzalezfj
CF Senior Member
gonzalezfj's Avatar
I respectfully disagree. This is a prime example of what can happen when you impose loads on a structure (the shock mount) that it was not designed or tested to resist.
You modify cars at your own risk. I am willing to bet money that this failure WOULD NOT have occured if the car had the OEM leaf springs.
Frank Gonzalez
gonzalezfj is offline
Old 05-25-2008, 05:16 PM   #14
RC45
CF Senior Member
RC45's Avatar
Yep - the very same arm chair quarterbacking done by the actual pro-rce teams who decided to go with the steel chassis vs the aluminium chassis o fthe C6 Z.
I am guessing there is a reason fo rthis - besides cost.
I do believe Short Throws car is based on a steel C6 chassis, not the alumium one - and I think it is safe to say that was a not a decision based purely on the cost of the steel vs alumium chassis.
RC45 is offline
Old 05-25-2008, 06:21 PM   #15
C6400hp
CF Senior Member
C6400hp's Avatar
Frank Gonzalez
And anyone that thinks otherwise is deluding themselves or does not understand the suspension configuration. This is not a knock on coilovers at all, lots of people use them and love them but, with the aluminum frame of the Z06 one has to wonder about longterm stress and fatigue damage from coilovers.
C6400hp is offline
Old 05-25-2008, 06:50 PM   #16
1stZ
CF Senior Member
1stZ's Avatar
Correct me if I'm wrong; but after looking the picture several time, does that picture shows that the shock mount/tower gave in and the coilover shock went up & through the shock mount/tower? In addition, if I may, how fast were you going when you hit the lumber? TIA Glad you ok and the car does not look too bad. Thx again!
1stZ is offline
Old 05-25-2008, 09:17 PM   #17
Randy@DRM
Premium Supporting Vendor
Randy@DRM's Avatar
I would love to see pictures of the upper top hat from the inside. IL, umm, maybe I will head that way to take a look???
Randy
www.dougrippie.com
Randy@DRM is offline
Old 05-25-2008, 11:33 PM   #18
Just J
Wizard of Odd.
Just J's Avatar
Quote:
I was braking down from 45 or so - going 25-35 when I hit it. Yes, the coil-over shock mount failed. There is fiber showing around the pushed-up area. There were pieces of some kind of cast aluminum disk in the engine compartment. I'm guessing that this was the actual mounting point under the chassis, and it broke into 3 or 4 pieces.
Quote:
Originally Posted by captain454 View Post
If one runs coil-overs and experiences this sort of failure, is there permanent damage to the frame of the car?
That's what I really want to know. Hopefully I'll know in the next few days.
Quote:
Randy
www.dougrippie.com
PM me if you want location specifics and contact info and we can make that happen.
Just J is offline
Old 05-25-2008, 11:34 PM   #19
1stZ
CF Senior Member
1stZ's Avatar
Randy
www.dougrippie.com
Please do & share with us your findings. Hopefully we could learn something that would help us (wishful thinking maybe?!) improve or even better come up with a fix to it.
1stZ is offline
Old 05-26-2008, 01:39 AM   #20
songman3
CF Senior Member
songman3's Avatar
I'm very sorry to read of your misfortune - life's a bitch for sure!
Glad you're OK
I hope you will post more information about your accident when you get it.
Most doubts about the suspension mount and the fitting of coilovers,concern not so much the structural strength of the mount itself, but rather the possibility of metal fatigue in the structure around the mount, caused by the continuous flexing of the frame on a long term basis.
How many miles have you done with the coilovers fitted?
songman3 is offline
Reload this Page Weird (aftermarket) suspension failure.
Closed Thread
Tags
c2, c5, coil, corvette, front, hanging, overloading, overs, problems, shock, shocks, strength, structural, suspension, tower
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
