Corvette Forum
Go Back   Corvette Forum > C6 Corvette, 2005 - ???? > C6 Z06 Discussion
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C6 Z06 Discussion
General Z06 Corvette Discussion, LS7 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track Sponsored by
PFYC
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 05-04-2008, 02:34 AM   #1
USA1-ZO6
Junior Member
USA1-ZO6's Avatar
Default Ls7 Bolt Torque Specs
Needing LS7 bolt torque specs, any help greatly appreciated! THANKS
USA1-ZO6 is offline   Reply With Quote
Old 05-04-2008, 02:50 AM   #2
vetteship
CF Senior Member
Which bolt ?
vetteship is offline   Reply With Quote
Old 05-04-2008, 03:50 AM   #3
toxin440
CF Senior Member
Quote:
Originally Posted by vetteship View Post
Which bolt ?
you mean there is more then one?
toxin440 is offline   Reply With Quote
Old 05-04-2008, 07:50 AM   #4
1coolC2
CF Senior Member
1coolC2's Avatar
These numbers are from one of the builders at Wixom. Sorry it's jumbled up a little, I had to copy it off a spread sheet and it won't keep the formating. Hope this helps.
R/
Jeff
DESCRIPTION TORQUE(Nm.)
CAMSHAFT RETAINER BOLT 25 +/- 4
OIL GALLERY PLUG 60 +/- 10
INNER MAIN BEARING CAP BOLT 20 (+/- 4) + 80 deg (+/- 3 deg)
OUTER MAIN BEARING CAP BOLT 20 (+/- 4) + 51 deg (+/- 3 deg)
MAIN BEARING CAP SIDE BOLT 25 +/- 4
CRANK SENSOR BOLT 25 +/- 4
CONNECTING ROD BOLT 20 (+/- 3) + 110o (+/- 3 deg)
TIMING CHAIN DAMPER BOLT 25 +/- 4
CAM SPROCKET BOLT 30 +/- 4
OIL PUMP BOLT - PRECONDITION 15 +/- 3
OIL PUMP BOLT 25 +/- 4
FRONT COVER BOLT - PRECONDITION 15 +/- 3
FRONT COVER BOLT - FINAL 30 +/- 4
REAR SEAL HOUSING BOLT - PRECONDITION 15 +/- 3
REAR SEAL HOUSING BOLT 30 +/- 4
OIL DEFLECTOR NUT 25 +/- 4
OIL PAN BOLT - M8 - PRECONDITION 15 +/- 3
OIL PAN BOLT - M8 - FINAL 25 +/- 4
OIL PAN BOLT - M6 12 +/- 2
LIFTER/GUIDE ASSEMBLY BOLT 12 +/- 2
VALLEY COVER BOLT 25 +/- 4
ROCKER ARM BOLT 30 +/- 5
VALVE COVER BOLT 12 +/- 2
INTAKE MANIFOLD BOLT 10 +/- 1
OIL PRESSURE SENSOR 35 +/- 5
CYLINDER HEAD BLEED TUBES/PLUGS 12 +/- 2
WATER PUMP BOLT 30 +/- 5
IGNITION COIL BOLT 12 +/- 2
HARMONIC BALANCER BOLT 50 Nm. (+/- 5) + 140 deg (+/- 4 deg)
KNOCK SENSOR BOLT 25 +/- 4
ENGINE MOUNT BRACKET BOLT 50 +/- 10
COOLANT TEMP SENSOR 20 +/- 4
EXHAUST MANIFOLD BOLT - PRECONDITION 14 +/- 2
EXHAUST MANIFOLD BOLT - FINAL 20 +/- 2
TORQUE SPARK PLUG 20 +/- 3
CYLINDER HEAD CORE PLUG 20 +/- 4
EVAP VALVE BOLT 50 +/- 10
LIFT BRACKET BOLT 50 +/- 10
FLYWHEEL BOLTS - FINAL (TORQUE + ANGLE) 30 Nm. + 40 deg
FLYWHEEL BOLTS - PRECONDITION 20 +/- 4
CLUTCH PLATE BOLT - FINAL 70 +/- 7
1coolC2 is offline   Reply With Quote
Old 05-04-2008, 11:33 AM   #5
USA1-ZO6
Junior Member
USA1-ZO6's Avatar
Quote:
R/
Jeff
Thanks Jeff !
Old 05-10-2008, 12:48 PM   #6
Bigbucks
CF Senior Member
R/
Jeff
Maybe it's obvious, but I wrote a couple of these numbers down (rocker arm bolt and valve cover bolt), not realizing they are N.m and NOT ft-lbs. Just before I installed the rocker arms, I posted requesting some advice and I happened to mention 30 ft-lbs. And a responder said he used 22 ft-lbs. Then one of the engine builders chimed in saying it was 30 N.m. Any way, just making sure that you realize it is N.m.
Bigbucks is offline   Reply With Quote
Old 05-10-2008, 03:18 PM   #7
RedGTS
CF Senior Member
This may be a little easier to read, and it has both N-m and ft/in lbs:
http://www.davidfarmerstuff.com/C6Z06-Torque.pdf
RedGTS is offline   Reply With Quote
Old 05-11-2008, 12:44 AM   #8
USA1-ZO6
Junior Member
USA1-ZO6's Avatar
Yes on the N-m and thanks again for all the info!
Old 05-14-2010, 12:56 AM   #9
triblk6spd
CF Senior Member
Support Corvetteforum!
triblk6spd's Avatar
The Wixom list says rocker arms 30lb/ft and the david farmer list says 22lb/ft? Which is it?
triblk6spd is offline   Reply With Quote
Old 05-15-2010, 01:34 AM   #10
triblk6spd
CF Senior Member
triblk6spd's Avatar
Nobody on this board has torqued down their own rocker arms? I am reinstalling my rockers next week and just want to double check. Thanks all.
Old 05-15-2010, 02:03 AM   #11
Z06LINK
CF Senior Member
Z06LINK's Avatar
yes I torqued mine when I replaced them with my CHE rockers. Checked the Chevy engine manual page 9-1099, "Valve rocker arms 30 N-m or 22 lb ft."
Z06LINK is offline   Reply With Quote
Old 05-15-2010, 02:19 AM   #12
triblk6spd
CF Senior Member
triblk6spd's Avatar
You are the best. Thank you for the help. When it comes to rockers on these cars you can never be TO sure.
Old 05-15-2010, 10:26 AM   #13
bowtiguy
CF Senior Member
bowtiguy's Avatar
I've installed and retorqued my CHE's several times... the man is right 22 ft lbs.
bowtiguy is online now   Reply With Quote
Old 10-15-2011, 01:40 PM   #14
erichg1000
CF Senior Member
has anybody been able to verify the differences between david farmer torque list and the above "wixom" list? Some are different. For instance spark plugs - 20 n.m on the above list. On the DF list it's 15 n.m
erichg1000 is online now   Reply With Quote
Old 12-30-2011, 05:55 PM   #15
vvlf
CF Senior Member
vvlf's Avatar
Quote:
Not sure what the conversion to n.m.'s are, but the chevy service manual says the spark-plugs are to be torqued to 11 ft-lbs
vvlf is offline   Reply With Quote
Old 12-30-2011, 06:02 PM   #16
erick_e
CF Senior Member
erick_e's Avatar
Quote:
Correct...
Rocker arm bolts are 30Nm or 22ft lbs
erick_e is offline   Reply With Quote
Reload this Page Ls7 Bolt Torque Specs
Tags
2007, 2008, bolt, c5, corvette, cover, flywheel, intake, ls7, manifold, specs, torque, valve, z06, zo6
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
C6 Z06 Frequently Asked Questions(FAQ) LTC Z06 C6 Z06 Discussion 56 08-02-2011 03:23 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
