[Z06] LS7 broken rocker arm needle bearings issue
#801
Can someone confirm on the Comp trunnion kit whether you reuse the stock bolts or use the comp supplied bolts to bolt the rocker back down once you install the trunnions? Read some threads where some used the stock bolts because the comp bolts were too long and others say the comp bolts worked fine so need to know which is it??
I have a 2007, I checked the build date and found it was 21 out of 32 Z06's built on july 10th 2006. It was #157 of 8159 Z06's built for the 2007 production year and 1 of 827 in LeMans Blue. I recently just checked my rockers to find that they are in perfect condition but just to be on the safe side since I am planning on some mods I am having them switched out for the comp cams trunions. I actually have two sets of the trunions and I only need one so if anyone wants a set pm me and I will send it out $130 shipped (us) brand new still in the wrapper. Oh and YES they do fit the LS-7 motors!!!!!
#802
Looks like there is still a difference of opinion on whether to use the comp bolts or stock ones. I guess I will wait till my rockers are back on with the trunnions installed and see the difference in bolt length before deciding which to use.
Another question to those that have done the upgrade. Did you take the parts out of the plastic packages and install or did you clean them up a bit and oil them slightly with engine oil before install??
#803
#805
Bearings were clean but the trunions were coated with heavy sticky preservative type oil and were dirty.
#806
Just took them out of the package and installed. Nothing wrong with allowing the prepacked grease to do its job
#809
Maligator:
The "Comp Cam" Trunion Kit took away almost any and all of that "sewing machine type" noise that has been described in this thread on my 2007 Z06. However,... let me add that my car did not have as much "valve train noise" as some of the other CF members have described.
I think that CF member vvlf also said the kit quieted his engine considerably too.
John_P
#810
Maligator:
John_P
Maligator:
John_P
thats excellent. I know vvlf said it was amazing how the noise was subdued, but I wasnt sure if he was specifically speaking of the sewing machine type noise..................definitely mod number 2!!!!!!
#811
Maligator:
Yes, the "Comp Cam" Trunion Upgrade is by far the BEST mod I have done on my 2007 Z06! I am sure CF Member vvlf will come in here and give you some more input. He and others helped me ALOT here on this forum with this particular issue on our Z06's and I am darn glad I became a member here. Being fairly new I look to the knowledge and experience of so many of these members and it has sure paid off!
Please let us know how the mod works on your Z06!
#812
Comp Cam Trunion Upgrade
Maligator:
Maligator:
#813
I see some red lock-tite material on my bolts too but I'll reinstall without it and keep an eye on things. If I have to pull the covers to retorque I might do the lock tite thing. Might be hard though since the bolt holes get oil in them and you need a clean area for the lock tite to really work. If it's torqued to specs it should stay there.
No problem getting my stock bolts off with the 8mm socket. Tried to do it with my regular 3/8 drive ratchet wouldn't budge. Went to the johnson bar and it cracked them all loose very easily. Loved the "ting" sound that you hear when the bolts cracked loose.
Might be a good idea to try that tape lock-tite sells now????
#815
#816
What if your build date is before January 1, 2007
Hi guys,
I am looking at purchasing a 2007 Z06 with 2200 miles that was built in October of 2006. Is it possible that this vehicle will have the rocker arm bearing issues also? I could not find any information on the site that talked about the problem on 2007 cars built before January 1, 2007.
Any help would be really appreciated,
Gary
Gary
#817
Hi guys,
Gary
Gary
Gary:
Welcome to the website Sir!
Gary, the majority of the LS-7 rocker arm problems seem to be on the early built 2007 Z06's. But, with that being said, all of the LS-7's have the basic same designed rocker arms with the lousy set-up on the needle bearings as has been well covered in this thread. In fact, if I am not mistaken, I think all of the LS engines have this same basic design. Some of the more veteran CF Members will correct me on this if I am wrong.
If you are seriously thinking of buying that 2007 you are looking at, i would suggest running the GM Maintenance History on the car along with a CarFax. If GM did any work on that engine, it will usually show on the GM History.
Hope that helps you some Sir.
John_P
#818
Hi guys,
Gary
Gary
However, even outside of the higher failure rate time frame there can be still be failures, but regardless, I would not let that stop me from buying the car.
Like John_P says, have the Chevy service department run the history on the car. If it is a private party sale, you may have to get the current owner to do it as sometimes the service department will not do it unless you own the car.
In the past there have been some people on this form that have had access to run the history, and when I was looking for mine I got it done that way on some cars, but ended up buying a new one instead. Don't know if anyone is still doing it.
If you are really paranoid about the issue, have the valve covers pulled and check the rocker arms.
#820
Rocker arms 2007 Z06
I know this is a old forum but I just know found it, my Z06 was built 11/06 but it just has 6200 miles on it, has anyone had problems with their rocker arms around this date. The dealer has not said anything about any problems with my car but I am going to have the oil changed tomorrow and tell them to check the drain plug .
