[Z06] WTF? airbag light?
WTF? airbag light?
was out with a few friends tonight and on the way home out of nowhere the airbag light flickers twice and then stays on for about 10 seconds then goes away all together.
any ideas?
any ideas?
Have the same annoying issue as well. Sometimes mine stays on the entire time while I am driving until I shut down and re-start. Can go weeks without it happening and then out of nowhere it happens again.......I thought maybe a software glitch on '06 Z's but you are an '08.......hmmmmm?
On the C4 the ground was on the frame positioned under where the condensation from the AC dripped. This corroded the ground and the service airbag light would flicker on and off intermittently. Good luck and keep us posted on what you find so if this pops up on my 09 z06 i know what to look for.
Supporting Vendor
Location: Supporting the Corvette Community at Abel Chevrolet in Rio Vista, CA 707-374-6317 Ext.123
Received 1,425 Likes
St. Jude Donor '08
It is common for the seat wiring harness connector to the airbag to wiggle loose from moving the seat back and forth. We have sen it quite a few times and the airbag jumper harness is usualy the fix. I would start there.
RICH
RICH
so look for a loose connection under the seat?
Had the same problem. When I pulled the seat to install the power lumbar bladder & motor...the plug was loose.
just checked and the two connectors that come up out of the carpet and the one yellow one on the back of the seat were all connected just fine.
