Corvette Forum
Go Back   Corvette Forum > C6 Corvette, 2005 - ???? > C6 Z06 Discussion
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ Photo AlbumsGarage
C6 Z06 Discussion
General Z06 Corvette Discussion, LS7 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track Sponsored by
PFYC
Old 11-07-2007, 07:10 PM   #1
DaWorm111
CF Senior Member
DaWorm111's Avatar
Default LMR 438ci C6 ZO6+250 shot Vid!!
Here is a quick video of Jacks aka (The Godfather's) c6 z06
http://videos.streetfire.net/video/6...df00ba1c73.htm
Car put down a pretty conservative 850rwhp.
Congrats Jack on a beast of a car!! This car weighs in at 3400lbs (equipped with a badass stereo system)
His best run with the car was at Lonestar 10.3 @ 14X with a cam and a 200 shot.
No question he will get into the 9's when he gets more seat time.
I will keep you guys posted.
Steven Fereday
Late Model Racecraft
713-466-9900
Latemodelracecraft.com
DaWorm111 is offline   Reply With Quote
Old 11-07-2007, 07:11 PM   #2
thegame
CF Senior Member
thegame's Avatar
Send a message via AIM to thegame
no workie
thegame is offline   Reply With Quote
Old 11-07-2007, 07:13 PM   #3
DaWorm111
CF Senior Member
DaWorm111's Avatar
Try now....it works for me....
Old 11-07-2007, 07:17 PM   #4
GaryZ06
CF Senior Member
Still no workie
GaryZ06 is online now   Reply With Quote
Old 11-07-2007, 08:35 PM   #5
DaWorm111
CF Senior Member
DaWorm111's Avatar
Quote:
Originally Posted by GaryZ06 View Post
Still no workie
Ummm, it should be working now.
Old 11-07-2007, 08:56 PM   #6
iw172
CF Senior Member
iw172's Avatar
Location: Retired early,everyday is Saturday...Hocking Hills Ohio
What a fast car......and he even launched bad.
iw172 is offline   Reply With Quote
Old 11-07-2007, 09:15 PM   #7
BAD Z06
CF Senior Member
BAD Z06's Avatar
Quote:
BAD Z06 is offline   Reply With Quote
Old 11-07-2007, 09:30 PM   #8
GrillnZ
CF Senior Member
That cars in the 9s already...the driver isn't though!
GrillnZ is offline   Reply With Quote
Old 11-08-2007, 11:29 AM   #9
DaWorm111
CF Senior Member
DaWorm111's Avatar
Quote:
Yea, the customer had no seat time in the car at all. He picked the car up from our shop and loaded it on the trailer and headed straight to bowling green for ZO6 fest. Once he gets a couple passes under his belt, I think he will get that 9 sec timeslip he is looking for.
Steven Fereday
713-466-9900
Old 11-08-2007, 11:50 PM   #10
Wanderer Z06
CF Senior Member
Wanderer Z06's Avatar
Car has the trap @ 142mph for a 9 sec pass that is for sure.
Is this car running a built bottom end?
With a 200 shot I would hope so.
Keep us posted!!
Wanderer Z06 is offline   Reply With Quote
Old 11-09-2007, 11:21 AM   #11
Z O SICK
CF Senior Member
Z O SICK's Avatar
Keep us posted!!
I'd like to know as well.
Z O SICK is offline   Reply With Quote
Old 11-10-2007, 08:05 AM   #12
Godfather
CF Member
Keep us posted!!
Yes it does have a built bottom end. It is an Ls7 stroker motor. My real problem is that I can not find true slicks for the car. John at CCW was able to come up with rims that take me to 17" but ONLY a drag radial is available in that size. Sure wish there was a way to get to 16". Any ideas? Spraying the 250 shot off the line just blows the tires! Might do much better at a track that has really been prepped properly. If you haven't ever raced at Beach Bend you will NOT know what I am talking about! I did have a better time than what that run was. On the next run I was at 10.7, but the track was gone after my 3rd run and called it quits for the day after that.
Jack
btw....I ran a 200 shot on the stock bottom end for a long time before I went to this new set up without any problems at all.
Godfather is offline   Reply With Quote
Old 11-10-2007, 09:36 AM   #13
J HEBERT
CF Senior Member
Support Corvetteforum!
J HEBERT's Avatar
Quote:
Jack
I use the M/T et street tire on 17x11 C4 wheels, low 1.4 60ft is the norm when leaving on a 100 shot w/ stock short-block, u are 2mph faster than me, u got a 9sec car there Jack
J HEBERT is offline   Reply With Quote
Old 11-10-2007, 11:43 AM   #14
FU
NCM Lifetime # 982
St. Jude Donor '06-'07-'08-'09
FU's Avatar
Location: NY- Love of Country with great fear of our present Government.
Hoosier and Goodyear make some killer DRAG radials. Not to be confused with a DOT drag radial.
As posted above J HERBERT's recomendation of MT ET Streets should do the trick. And help minimize breakage.
That is one bad azzed car you have there.
Some seat time and a bit of traction .. LOOKOUT !
FU is online now   Reply With Quote
Old 11-10-2007, 12:01 PM   #15
tjwong
CF Senior Member
tjwong's Avatar
Send a message via AIM to tjwong
Jack
Jack are you running one of those fancy electronic progressive NOS controllers? If not, you may think about trying one, it brings on the NOS in a controlled ramp that you dial in, that way you get a good launch and then it cranks up.
http://holley.com/15975NOS.asp
tjwong is offline   Reply With Quote
Old 11-11-2007, 05:01 AM   #16
Wanderer Z06
CF Senior Member
btw....I ran a 200 shot on the stock bottom end for a long time before I went to this new set up without any problems at all.[/quote]
Wet or dry shot?
Old 11-11-2007, 07:28 AM   #17
Godfather
CF Member
Wet or dry shot?[/quote]
WET!! Don't like it dry!
Jack
Old 11-11-2007, 07:32 AM   #18
Godfather
CF Member
Thanks for the info.This may be exactly what I need. Tires blowing up off the line as you noticed from the video. They are M&H and were doing good when hp was at 725. Beach Bend also did NOT prep the track very well at all. I was spinning in 4th as well.
Jack
Old 11-21-2007, 01:02 PM   #19
DaWorm111
CF Senior Member
DaWorm111's Avatar
We will be installing something very similar to that. We will post up results once we hit the track again.
Steven Fereday
713-466-9900
Old 11-21-2007, 03:06 PM   #20
Live2Redline
CF Senior Member
Live2Redline is offline   Reply With Quote
Reload this Page LMR 438ci C6 ZO6+250 shot Vid!!
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertise Here - Contact Us - Corvette Enthusiast Discussion Forum - Archive - Top
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
