Corvette Forum
Go Back   Corvette Forum > C6 Corvette, 2005 - ???? > C6 Z06 Discussion
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C6 Z06 Discussion
General Z06 Corvette Discussion, LS7 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track Sponsored by
PFYC
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 08-26-2007, 10:32 PM   #1
C6 Twin Turbo
CF Senior Member
C6 Twin Turbo's Avatar
Default Recommendations for brake pads
I am looking for help to get recommendations for brake pads. I do run about 6-7 road track days a year. I would appreciate any recomendations for who and where to get pads that would be best for my application.
C6 Twin Turbo is offline   Reply With Quote
Old 08-27-2007, 08:23 PM   #2
gmk
CF Member
gmk's Avatar
Default Same question.
I have the same questions. I have tried the Hawk HP+ pads and have mixed reviews, they are just OK at the track but terrible on the street. There must be something available that works better. I had very good luck with the HP+ pads on my C5-Z but not so good with the C6-Z. I really don't want to do a complete brake upgrate if I don't have to, the C-6 brakes seem to be an upgrade from the C-5 but are they?
gmk is offline   Reply With Quote
Old 08-28-2007, 06:21 PM   #3
sleeplessinseattle
CF Member
I have driven my 2007 Z06 on 2 track events, both at Pacific Raceways in Auburn, Washington. The first event was on the stock pads. They provided decent stopping power but wore out about 2/3's of the pads in front.
Based on the advice of many forum members I bought a set of RacingBrake ET700 pads. On the next track day the pads were terrible on the first 2 runs. Very poor grip. On the 3rd session they came in and worked much better than the stock pads. I had two drivers on this day and made a total of about eight 20 minute runs. Very little wear, maybe 10-15%. I attribute the poor initial performance to a difference in coating the stock pads leave on the rotors versus the new pads and it takes a bit to wear through and seat in.
I have driven the pads on the street with mixed results. They are OK in normal street driving but will grab unevenly if you try to do a hard stop when the pads are cold.
Another forum suggestion was to install the RB retainer bolts on the stock calipers. Getting the stock heck bolts out was tough. I tried to replace all of them with the new bolts for appearance reasons but I was unsuccessful. On about 5 bolts I striped the hex head and the bolt is still in the caliper. Fortunately only the center bolts need to come out to change the pads.
Hope this helps.
sleeplessinseattle is offline   Reply With Quote
Old 08-28-2007, 08:51 PM   #4
American Power
CF Senior Member
American Power's Avatar
I went through a few different combos with the stock calipers.
I started stock, OK for starting out.
Then went to HP Plus and it was better, a little squeeky on the street but great initial bite. They did fade after a few laps on the track and warped the stock rotors.
Then...
RB slotted (not drilled) 2 piece rotors with Hawk DTC70's up front and DTC 60's in the rear.
They never fade. No warping. I have 2 HPDE's on the pads so far with very little wear. With hard breaking from 165 down to 80mph.
Once you do a few track days you will realize there is no single all purpose pad.
I switch back to OEM pads when driving around town. The squeeeeeeeeeeeeeek of the race pad is unbearable when not up to temps they hit on the track. It sounds like a bus stopping.
American Power is offline   Reply With Quote
Old 08-28-2007, 09:30 PM   #5
z06jones
CF Member
Support Corvetteforum!
Send a message via Yahoo to z06jones
I've not found a great dual use pad. Racing Brake ET800s are about as close as I found. About the same squeaking on the street as Hawk HP+ (maybe a little less) and better braking at high speeds than HP+.
As others have said ET700 are very quite on the street and slightly better than stock on the track. But as you gain experience and run harder they don't have high enough torque for slowing down from 160s and 170s
Currently I'm running ET900s on the track (similar to DTC70s) and stock pads on the street. You just can't beat high end track pads on the track.
z06jones is offline   Reply With Quote
Old 08-29-2007, 06:03 PM   #6
urslooow
CF Senior Member
urslooow's Avatar
Forget the dual purpose pads. I use Hawk DTC 70's all around and leave them on for the street AND I use my z as a DD. I take off the calipers to chg pads. if you can't stand the noise (a) chg to stock or Hawk ceramics betw events or (b) let the car slow down on the gears more, and let off the gas a little sooner. Pretty soon all you'll care about is track driving, the street stuff is BORING so why push it?
urslooow is offline   Reply With Quote
Old 08-29-2007, 08:02 PM   #7
jswatek
CF Senior Member
jswatek's Avatar
Who cares if they squeek? Its the sound of high performance. I want a safe street pad that won't put deposits on the rotors at low street temps but work well on the track. Squeeking and dust don't bother me,
jswatek is offline   Reply With Quote
Reload this Page Recommendations for brake pads
Tags
2006, bolts, brake, brakes, c5, c6, calipers, corvette, factory, pad, pads, rb, retainer, reviews, stock, z06
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
New Brake pads RickMz C6 Corvette General Discussion 19 01-13-2005 01:03 AM
Want to swap out brake pads. Recommendations please circusvargas1 C5 Tech 38 02-21-2004 10:40 AM
Best Brake Pads for the C4 ??? Alex D C4 Tech/Performance 21 04-21-2003 11:03 PM
Brake Pads - PFC, Hawk, or CarboT? Rx7Rob Autocrossing & Roadracing 44 09-16-2002 03:49 AM
Brake Pads Recommendations wheelsup Drag Racing 33 07-10-2002 01:02 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
