[Z06] The C6 Z06 Fast List
#1721
I'm hesitant to put this timeslip up... didn't hook-up hard on it. Have now ran as fast as 1.39 60 ft with a 6.47 et at the local 1/8th mile track, but having problems getting a good hook at my local 1/4 mile track. But, it is an improvement and does change the list, so I'm going ahead and submitting. Much better to come.
Year of the Z06: 2006
Tires used on the pass: Hoosier 315/35-17 Drag Radial
Performance Mods (if any): K&N CAI, Katech Torquer 110 cam, WCCH Stage 2 heads, ARH 1 7/8" Headers with cats, Auto 4L65E conversion
Category submitted for: Internal Engine Mods plus Bolt-Ons
60'............. 1.460
330'........... 4.270
660'........... 6.644
660’ mph... 103.16
1000'.......... 8.712
1320'..........10.458
1320’ mph… 129.33
Name of the track: Texas Motorplex (Ennis, TX)
Date of pass: July 19, 2014
Weather conditions: (include Density Altitude, if known): approx DA 1600 Feet
Image of complete Time Slip:
Link to Corvette Forum thread containing report: None
Link to Video: None
660’ mph... 103.16
1320’ mph… 129.33
Link to Video: None
I think I could squeeze a 10.3X@ 132+ out of my Torquer 110 package if I had better air to run in, but I have to agree with you.....I'd need to switch to the K501 to run higher traps as the 110 doesn't have the top end breathing ability and is not a drag racing cam.
#1722
Nice pass !!!!
Yeap... when I put this Katech cam in, I wasn't planning on racing it. But, I sold my old bracket car and needed something new, so here I am.
I actually now think I can get into the 9's with this Katech 110.....that 10.45 above pass had tire spin on the initial hit, I have trouble hooking-up clean on this 1/4 mile track as does everybody from what I am told. Most of my racing is on a local 1/8th mile, hence my best passes due to the volume I race there, which is a 1.39 60 ft, 6.47 @ 105 mph thus far. That equates into a 10.2x, and this is in the summer. Most full hooks passes right now in summer air is 1.39 to 1.42 60 ft. This should be mid to high 1.3's in average fall air and I would think 10.0's minimum. But, just guessing....I'll find out for sure in a couple of months.
The above is with the stock Intake and TB.... just added a Fast 102 and TB this week. Hope to find a tenth and mph with that. Will find out tonight at the local 1/8th track.
I think the K501 would make it a little easier, based upon my simulation modeling of the engine torque curves Katech has released on both cams, it'd pick up 1 to 1.5 tenths and 1.5 to 2.0 mph vs the Torquer. Not bad at all.
I also have a big lumpy Mike Jones spec'd cam in my garage.... if push comes to shove, I'll install it someday.
#1723
With that auto conversion, you'll be damn close
#1725
You have any weight reduction, or run a drag pack ?
If not, that just might be enough to go sub 10.0, but I think it will be close.
I went a 10.404 on a 6.587@105.22 1/8th split one night back in January in Arizona, full weight with my 20x10 ZR1 runflats on the front, but the cam lays down after 6300 RPM, so the traps speeds are not as big as some of the more drag oriented cams. The K501 pulls all the way to 7000, IIRC.
#1726
I run a Weld RT-S dragpack..... I have no other weight reductions. Sometimes I have the passenger seat out depending on if I am changing tires at the track, but I've run before and after on that and only helps a few hundredths at best. I think I added weight with the Auto conversion, but not sure.....and I weigh 270 lbs, so its not a lightweight. At the Texas Motorplex it indicated 3300 lbs, but I'm told that scale was off, so I don't know what I weigh for certain.
With you... I've raced Firebird, that is not a fast track, especially in the summer. Get yourself away from their, maybe up the coast in California and you'll pick-up several tenths in my opinion. You don't have any fast tracks around their.... Vegas is even slower.
#1727
Tires used on the pass: 315/35/17 hoosier drag radial
Performance Mods (if any): H/C/I, 12:1, 2" ARH LTs with 3" offroad xpipe, 3" B&B fusion Catback, Diamond pistons, Vararam CAI, stock ported TB and methanol injection to prevent knock retard...
60'............. 1.53
330'........... 4.300
660'........... 6.613
660’ mph... 105.98
1000'.......... clock was messed
1320'.......... 10.226
1320’ mph… 137.08
Name of the track: Toronto Motorsports Park
Date of pass: August 8, 2014
Weather conditions: 1500 DA
http://forums.corvetteforum.com/c6-z...for-9s-na.html
660’ mph... 105.98
1320’ mph… 137.08
#1728
660’ mph... 105.98
1320’ mph… 137.08
660’ mph... 105.98
1320’ mph… 137.08
Please post a Complete Timeslip so it may be added to the Fast List.
TIA
#1731
Year of the Z06: 2009
Tires used on the pass: Goodyear runflats
Performance Mods (if any): Halltech MF105 air intake
60'............. 1.99
330'........... 5.1084
660'........... 7.6043
660’ mph... 100.12
1000'.......... 9.7217
1320'.......... 11.5161
1320’ mph… 122.41
Name of the track: Sacramento Raceway
Date of pass: 8/20/14
Weather conditions: (include Density Altitude, if known): DA was 1250ft
Although Ive had a few C5Z and C6Z this was the first time out in this car, and on stock Goodyear runflats. Im happy with the time for now, need to wait for some better weather and put some better tires on it.
660’ mph... 100.12
1320’ mph… 122.41
#1732
660’ mph... 100.12
1320’ mph… 122.41
660’ mph... 100.12
1320’ mph… 122.41
To be updated on or about 9/1.
#1733
Year of the Z06: 2007
Tires used on the pass: 345 NT05R
Performance Mods (if any): P1 Procharger @ 4.5psi, comp cam, 60lb injs., RAM twin disk
60'............. 1.80
330'........... 4.716
660'........... 7.077
660’ mph... 104.74
Name of the track: Screven Dragway 1/8 mile (GA)
Date of pass: 6/21/14
Weather conditions: (include Density Altitude, if known): Clear
Very first trip to the track with the car since I picked it up about 4 months ago.
660’ mph... 104.74
#1735
330'........... n/a
660’ mph... 104.74
Date of pass: tbd
I will find the slip and update the date this evening. It was about 2 months ago. Very first trip to the track with the car since I picked it up about 4 months ago.
330'........... n/a
660’ mph... 104.74
Date of pass: tbd
Since this is only an 1/8 mile pass, it cannot be placed on the Fast List. However, your info is beneficial to the community.
#1736
Yes. The Halltech does increase the performance and there is no separate category. I can tell you that a simple drop-in air filter that was not stock pushed my 1st entry on the C5Z Fast List to the C5 Z06 CAI and DOT Tire Times (drag radial and bias ply) category. That was back in 2004 when I first met Ranger. I immediately replaced that K&N filter with an OEM paper filter and ran quicker.
#1737
Hi I want to summit my pass to the fast list
Tires used on the pass: 26/11.50 et streets bias ply and m&h front runners
Performance Mods (if any): LG Headers, Borla, K&N, fast 102 intake, 102 tb, wcch 2 heads, black panther cam and tune by Jeremy
60'.............
330'........... 4.398
660'........... 6.761
660’ mph... 104.15
1000'.......... 8.795
1320'.......... 10.510
1320’ mph… 132.05
Name of the track: Orlando Speed
Date of pass: 08/27/14
not sure
Link to Corvette Forum thread containing report: https://www.corvetteforum.com/forums...ure-plans.html
Link to Video: https://www.youtube.com/watch?v=7UpC...ature=youtu.be
60'.............
660’ mph... 104.15
1320’ mph… 132.05
not sure
#1738
60'.............
660’ mph... 104.15
1320’ mph… 132.05
not sure
60'.............
660’ mph... 104.15
1320’ mph… 132.05
not sure
#1740
Year of the Z06: 2011
Tires used on the pass: MT Radial PROs
Performance Mods (if any): LS7 with stock rods, stock crank, stock sleeves, Diamond pistons, Twin-Turbo 58/65s, PRC 285 heads, cam, stock trans, stock diff, stock axles, Mantic clutch, stock suspension, 18.5psi ~1000hp / 1100tq
Category submitted for:Power Adders
60'.............1.429
330'...........4.046
660'...........6.214
660’ mph...116.74
1000'..........8.054
1320'..........9.587
1320’ mph…147.73
Name of the track:Renegade Raceway
Date of pass:Aug 30, 2014
Weather conditions: 70's and dry, DA unknown
Link to Video:
660’ mph...116.74
1320’ mph…147.73
Link to Video:
