[Z06] Naca Duct in front of Z06 question/diffused?
1 Post
Cruise-In XII Veteran
Guys and girls,
I searched for this answer first but could not find anything close. I thought that the Naca Duct on the front brought in cold air?
Upon installing my HallTech I took a good look and can not see light through it. Do you have any information on how much air leaks through or the heat in the cavity from where the KB gets it's air? I was under the impression that there wasn't a need for ducted air? Am I wrong?
StreetRod
StreetRod
I swiped this from another forum.
Quote:
Originally Posted by ZO6isthebestever
Why is it that the hood scoop isnt functional. They should of made it functional could help out in the air intake maybe could be a forced air intake. hmmmm Im thinking here
It is functional. Cold air is directed downward through the duct to the top of the AIS and is brought into the intake from the bottom of the entrance to avoid turbulence.
All other methods of bringing cold air into the airbox creates airflow vector disturbance, which causes surging under very low throttle positions.
Local thread.
http://forums.corvetteforum.com/show....php?t=1704442
Do a search using NACA
Watch the vidio link.
Local thread.
Local thread.
Local thread.
Get Some!
The NACA duct or NACA scoop is a common form of low-drag intake design, originally developed by the National Advisory Committee for Aeronautics (the precursor to NASA) in 1945. When properly implemented, it allows air to be drawn into an internal duct, often for cooling purposes, with a minimal disturbance to the flow. The design was originally called a "submerged inlet," since it consists of a shallow ramp with curved walls recessed into the exposed surface of a streamlined body, such as an aircraft. It is especially favored in racing car design.
Prior submerged inlet experiments showed poor pressure recovery due to the slow-moving boundary layer entering the intake. This design is believed to work because the combination of the gentle ramp angle and the curvature profile of the walls creates counter-rotating vortices which deflect the boundary layer away from the intake and draws in the faster moving air, while avoiding the form drag and flow separation that can occur with protruding inlet designs. This type of flush inlet generally cannot achieve the larger ram pressures and flow volumes of an external design, and so is rarely used for the jet engine intake application for which it was originally designed, (the North American YF-93 and Short Sherpa being exceptions.) It is, however, common for engine and ventilation intakes.
http://en.wikipedia.org/wiki/NACA_duct
"All other methods of bringing cold air into the airbox creates airflow vector disturbance, which causes surging under very low throttle positions."
I have a Vararam intake and have no surging whatsoever.
If I pull off to the side of the road and put my hand on the throttle body it's ice cold. Plus, it works!
GM should have made that scoop function like Ram Air.
These other explanations are Jibberish at best.
Get Some!
thx jim and maj thats good info i always wondered why the hose intake didnt work hey where can we get that bumpstick naca mod at?
Ram air is not Jibberish. It is functional and it's proven. The air that "seeps" through the little space around the "cosmetic NACA duct" and that's what it is "Cosmetic" is a Joke.
GM should have designed the intake to mount up to that duct.
Supporting Vendor
St. Jude Donor '09
Our Tech 2 says otherwise. 70 degree day: 120F IAT reading within 1 minute at idle. Moving at only 25 mph, in 1 block IAT drops 45 degrees to 75, and is in parity with the OAT within 1/2 mile.
I agree that GM might have thought this out better, but they did not want underhood lift to exceed a specified amount at speed.
Mother nature knows best. Bottom breathers, are also self cleaning during the rain.
Supporting Vendor
St. Jude Donor '09
http://www.sportrider.com/tech/146_9912_ram/
BTW. The NACA duct is strictly an ambient air induction system, and it does work as billed.
JIm
Get Some!
Ram Air works. It is real and provides a small amount of boost at high speeds, usually over 100 mph, but only when there is no filter in the pressure zone. Most high performance motorcycles have a version of ram air onboard, but the filters negate most of the gains that they would otherwise see from the pressures that develop. Anyone who does not believe ram air works, should visit a Pro Stock in the pits and ask the crew chief. It has been used for many years and is a proven science.
JIm
JIm
Jim, I agree with you about the filter. But, Having a reserve of cold air pressing against the filter is making it easier for the engine to suck down the air it needs when the throttle is opened up.
Therefore the engine is not sucking through the filter without assistance. Forced air on the outside of the filter is creating some pressure on the filters surface.
It makes sense and I feel it on my car. Especially at 100+ MPH.
Supporting Vendor
St. Jude Donor '09
I used to make and design ram air systems for drag bikes, so I have some background. We were doing this on the Suzuki's before it became standard OP.
Jim
