[Z06] new best bolt on car c6z06 10.76@129.7
so today was the corvette chalange so i took the ride down on my new drag radials 315 35 17 took me 3 passes to get the launch right but on the 4 pass bam it was out and i was not backing off
60ft 1.565
330 4.510
1/8 6.937
mph 102.54
1000 9.016
1/4 10.764
mph 129.77
great pass car was flying air was great and prep was good at e-town
now the bad news ill put that in a seperate post
60ft 1.565
330 4.510
1/8 6.937
mph 102.54
1000 9.016
1/4 10.764
mph 129.77
Leeds.io
St. Jude Donor '14-'15-'16
Nice run. Can you list all your mods please.
I see you managed .3 better than I on the 60' with the same setup. I knew I was doing a terrible job.
Is your 1/8 supposed to be 6.937 instead of 9.937?
Originally Posted by m3corvette
Great run! Sounds like you broke something.
nothing broke wish it was that easy car preformed flawlessly betcar ever built i will be getting another one same thing
Very nice pass, George! Congratulations.
And condolences on the misfortune of the accident; glad you walked away from it.
phantasms, Not quite the same set-up you're running. George previously posted about his Spec stage 5 clutch going in. That's one path to a strong 60'. Aftermarket clutch also gives better hook on the 1-2 and 2-3 because of its stronger clamping power and greater heat tolerance.
Of course, several owners have burned up new aftermarket clutches too. So there is not proven clutch for the LS7 yet. But certainly the stock clutch is not up to a stong launch because it glazes on launches about 3500 and will not accept slip to capture the inertia in the flywheel, the key to a strong leave.
Ranger
Originally Posted by phantasms
...Can you list all your mods please.
I see you managed .3 better than I on the 60' with the same setup. I knew I was doing a terrible job....
Ranger
Ranger
Ranger
ranger clutch is still stock actualy gave me problems on the 2nd pass with sticking to the floor
george
Originally Posted by 07BlueDevilZ06
mods are
kooks 1 7/8 headers with offroad x pipe
halltech f1 filter with cold air
ported intake and t-body
bfg 315 35/17 drag radial
160 stat
hp tuners
george
160 stat
hp tuners
george
60ft 1.565
330 4.510
1/8 6.937
mph 102.54
1000 9.016
1/4 10.764
mph 129.77
60ft 1.565
330 4.510
1/8 6.937
mph 102.54
1000 9.016
1/4 10.764
mph 129.77
I'm sick over the car, glad your fine.
60ft 1.565
330 4.510
1/8 6.937
mph 102.54
1000 9.016
1/4 10.764
mph 129.77
60ft 1.565
330 4.510
1/8 6.937
mph 102.54
1000 9.016
1/4 10.764
mph 129.77
George,
Great, great run and excellent driving! Amazing 60 ft. time. The is the best time I've seen yet with just bolt ons. I was thinking the 315 35 17 would work well, looks like you confirmed it! You also confirmed the car has the potential to be a 10 second car with just bolt ons.
Sorry to hear about the accident, but like other people said, glad nobody was hurt. Hopefully you can find another Z quickly!
Ranger
Ranger
I agree with you on the clutch. If a better solution comes out for this clutch, we will some some good improvement in these ETs yet. I can't launch this thing the way I really want to.
St. Jude Donor '09
oooppps my bad . sorry about yer fender dender sounds like a # 10 on the pucker factor. want towing company has yer car ? midnight auto supply wants yer motor. just kiddin
mods are
160 stat
hp tuners
george
160 stat
hp tuners
george
Awesome run!! I have not seen any 60' times that good out of a Z. Does your HP Tuners software edit out Traction Management? Are you running QA1 shocks or the stock ones? Stock half shafts?
So sorry to hear about your accident. Main thing is that you're safe. Will they let you unbolt the mods you did to the car? Good luck in finding another Z real soon.
John
Supporting Vendor
St. Jude Donor '09
mods are
Halltech F1 filter with cold air
160 stat
hp tuners
mods are
160 stat
hp tuners
Congrats on an outstanding run. What a flight. Which one of our filters did you use? The 2-Stage Foam or the RACE foam?
Sorry about your mishap. The vette has a very confining atmosphere when you are in an accident. I know. Glad YOU are ok.
Jim
