Go Back   Corvette Forum > C6 Corvette, 2005 - 2013 > C6 Z06 Discussion
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C6 Z06 Discussion
General Z06 Corvette Discussion, LS7 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track Sponsored by
PFYC
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 04-06-2006, 02:45 AM   #1
RD in SD
CF Senior Member
RD in SD's Avatar
Default Z06 Tires - which is best?
What is the best street tire for my 2006 Z06. Many of the test I have read etiher do not include the F1 Supercar EMT or rank it very low. My past experience with factory vette tires tells me that the Goodyears are not the best handling. I will drive on the street not at the track and I do not care much about wet handling as I live in San Diego. I do care about cornering, braking, comfort and noise.
I can't seem to find a decent test that covers ultra performance tires. Consumer Reports ranks the Eagle F1 GSD3 the best and so does the Tire Rack and Car and Driver. Problem is that it is not available in 325 size. Does anyone have experience with this size tire.
Also what is the largest tire you can squeeze under these big fat fender flares both front and rear? The Michelin Piliot Sports come in a 345/30/19 which seem tempting. Although Car and Driver was not impressed with this tire.
Help
RD in SD is offline   Reply With Quote
Old 04-06-2006, 06:34 AM   #2
Evado
CF Member
Evado's Avatar
Default Best tires for Z06
Help
You're kind of stuck. I spend quite a bit of time at the track, and have a C6 Z51 in addition to a Z06 (2006). There are no tires for the Z06 at this point. I put the Michelin Pilot Sport PS2's on my C6 and what a mistake. There is no tire pressure where these tires are "grippy" at all. The Potenza street tires were better than the PS2's, but there is nothing in your size available at this point.
To be honest, the run flats on the car are not bad at all, but don't cut it at the track. I am personally having custom 18" wheels made for front and rears which gives me all kinds of choices in terms of tires. I am going with a high end wheel (Fikse) which are very expensive, but want to use racing slicks on the car.
If you are using the car for the street only, the run flats are fine. I was able to beat lap times on every Porsche at a local Porsche event (with the exception of one race setup Porsche driven by a Pro....but I was close) with the run flats, so they are not terrible. For the street they are fine though, and I have been surprised at the fact that even at 1.3G they do not break loose.
They only lasted less than 1000 miles though but the PS2's lasted half that, so there you have it: Have custom wheels made for the car, wait for someone to come out with non-run flats, or wait for somoeone to come out with wheels for it which allow other tires. Check with the tire rack (a phone call is needed) to see if they have a wheel / tire combo which will work.
-Evado
Evado is offline   Reply With Quote
Old 04-06-2006, 10:22 AM   #3
RD in SD
CF Senior Member
RD in SD's Avatar
Default Good Info
Thank you very much, I also found a Pirelli in the 345 size, F1 Supercar in a 315 and a Contenental in a 315. Any comments on those tires.
Old 04-06-2006, 11:11 AM   #4
A427MAN
CF Senior Member
A427MAN's Avatar
I have driven the Spring Mountain Track with the stock Goodyears - they are (surprisingly) very good! The grip was excellent - and I pushed then super hard - also, they are quite predictable and squawk nicely when you push the car to its limit in comp mode. IMHO, there is NO REASON to change them for street use! It will be near impossible for you to outdrive them on the street!
A427MAN is offline   Reply With Quote
Old 04-06-2006, 12:10 PM   #5
allanlaw
CF Senior Member
allanlaw's Avatar
Quote:
Maybe by the time you wear them out something better will come along, but you don't want to be the test sled for tires.
allanlaw is offline   Reply With Quote
Old 04-06-2006, 12:22 PM   #6
outnumbered
CF Senior Member
Support Corvetteforum!
outnumbered's Avatar
I saw somewhere they are being offered.I think it was Nittos.I will try to find where I saw this.
outnumbered is offline   Reply With Quote
Old 04-06-2006, 12:59 PM   #7
Futfixr
CF Senior Member
Futfixr's Avatar
Quote:
I hope they come out with something soon. It requires alot of self control to make these run-flats last.
Futfixr is offline   Reply With Quote
Old 04-06-2006, 04:37 PM   #8
black97magic
CF Senior Member
black97magic's Avatar
Tirerack has Pirelli PZero Rosso in 355/25-19 $493 each
black97magic is offline   Reply With Quote
Old 04-07-2006, 01:52 AM   #9
RD in SD
CF Senior Member
RD in SD's Avatar
Default 355 Pirelli ?
Can't find um at Tire Rack, Where did you find them?
Old 04-07-2006, 11:09 AM   #10
MikeG06
CF Member
MikeG06's Avatar
Default this is weekly subject
OEM (GY) tires when cold - dangerous.
I'm with those waiting for street tire made of rubber compound that remain soft at lower temperatures ....
My understanding is that race tires are coming soon, but have not heard anything yet about for-the-street replacement. IMO many C6Z owners from northern states and provinces would benefit from such.
Mike
MikeG06 is offline   Reply With Quote
Old 04-08-2006, 06:50 AM   #11
LS WON
CF Senior Member
LS WON's Avatar
Quote:
I read that Kumhos were suppose to be the best for the $$$.
LS WON is offline   Reply With Quote
Old 04-08-2006, 12:39 PM   #12
vettemaster1
CF Senior Member
i know of no tire that works well when cold!....my race tires take warming up before they work....even when its 100 out.....my tires require at least 120 to 140 to be at their best....thats for an autocross compound.....race compound tires require more heat....
i also have used my street tires for autocross....and i was most impressed how well they did....really impressed!.....most others at that event were inpressed also when their c5z's on race rubber were getting beat by my c6z on the run flats!!
IMO....you wont do better than the run flats on the c6z....
when its cold out you simply cant get on it....when tires are cold you simply cant get on it......no rocket science here.....
vettemaster1 is offline   Reply With Quote
Old 04-08-2006, 04:17 PM   #13
RD in SD
CF Senior Member
RD in SD's Avatar
Default How wide can you go?
Assuming that they made a wider tire that worked well does anyone have any experience running wider front and rear tires on their Z06? I thought I read that someone had put 345s on the rear which does not seem like much of a problem. What about the fronts, how wide can you go?
Old 04-08-2006, 04:35 PM   #14
A427MAN
CF Senior Member
A427MAN's Avatar
I believe I read that both Jim Hall and Lou Gigliotti have put the Viper 345's on the rear.
Old 04-08-2006, 05:12 PM   #15
RD in SD
CF Senior Member
RD in SD's Avatar
What brand of tire dowes a viper come with?
Old 04-08-2006, 06:28 PM   #16
A427MAN
CF Senior Member
A427MAN's Avatar
345/30/19
http://www.tirerack.com/tires/Compar...YR&RunFlat=All
Old 04-09-2006, 01:42 PM   #17
MikeG06
CF Member
MikeG06's Avatar
My understanding is that the Michelin PS 345/30/19 on 12" wide rim has a narrower foot print then the OEM GY. Besides, they are also expensive. IMO this is a drivability issue, 'is my tires are warm enough to safely pass that Honda' We need tires for the street from this group,for example - http://www.tirerack.com/tires/survey...jsp?type=UHPAS : also Toyo T1R and others if and when available at the right size for the rear, front size is available from many.
Old 04-10-2006, 10:09 AM   #18
vetdude
CF Senior Member
vetdude's Avatar
They only lasted less than 1000 miles though but the PS2's lasted half that, -Evado
Less than 1k miles? I've only got 580 miles on my car; guess I better start looking for tires? I don't think so! I hope that includes miles of track use!!!!!!
vetdude is offline   Reply With Quote
Old 04-10-2006, 10:30 AM   #19
dmaccor
CF Senior Member
dmaccor's Avatar
it was on ebay
http://cgi.ebay.com/ebaymotors/ws/eB...tem=8043002504
nice package, but i have no idea how good Nittos are??
dmaccor is offline   Reply With Quote
Old 04-10-2006, 10:49 AM   #20
jlvink66
CF Senior Member
jlvink66's Avatar
I don't think the eBay deal with the Nitto's is meant for the C6 Z06. Rear wheels are only 10.5 wide. The Nitto's must be a lot smaller than 325 to fit that wheel (They don't list the tire sizes??)
jlvink66 is offline   Reply With Quote
Reload this Page Z06 Tires - which is best?
Tags
2006, c5, c6, comparison, corvette, covette, forums, rear, recommendations, sale, size, tire, tires, tyres, z06, zo6
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
