C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] 2 rear diff sensors???
Old 04-20-2005, 04:52 PM
runamuk
runamuk's Avatar
Cruise-In V Veteran
St. Jude Donor '04
Default 2 rear diff sensors???
Thanks to Monica at Maxiprice for this picture from Road Atlanta
I noticed the rear diff has to sensors in the case, 1 being the VSS but does anyone know what the other is for ...Temp maybe???
Old 04-20-2005, 07:29 PM
TedDBere
TedDBere's Avatar
Probably to check for leaks...could have used that on the C5s!!
Old 04-20-2005, 08:10 PM
greenshirt77
greenshirt77's Avatar
Maybe with a larger image, we might be able to tell.
Old 04-20-2005, 08:50 PM
Mike903L
Mike903L's Avatar
I think I read that the rear end has it's own cooler, so it's a good guess that the second unit is some type of temp gauge.....
Old 04-20-2005, 09:38 PM
rgregory
rgregory's Avatar
I wouldn't think is was a temp sensor since at the top all it can read is case temperature since the fluid only partially fills a diff.
To 2 rear diff sensors???
Quick Reply: [Z06] 2 rear diff sensors???
