Saw a C6 race at Englishtown
Dave Busch, from Cartek, brought his virgin C6 coupe to the Corvette Challenge today and made a few runs on the 1/4 mile. Most of the run's I saw were around 13.4's, though bear in mind that the surface was hot and the DA was poor (~2000?). I also think that Dave was still getting use to the shifter in this new car.
Dave & Julio,
Here are two pictures of your new car:
http://www.rbartick.com/cf/cartek_c6_1.jpg
http://www.rbartick.com/cf/cartek_c6_2.jpg
Originally Posted by Cobra4B
Nice ride =) time for the X package Can you tune that torque management crap out?
CI 3-5-6-7-8 Veteran
Originally Posted by los7883
Hopefully it won't be long before we start seeing some packages for the C6...
So just the bore/stroke are different? It will still be a while before a catback system is ready for it, looks like there may be a set of headers out right now that fit it, "LS2 Edit" still isn't available yet...are the intake and the throttle body the same? What about the drivetrain? I would think it is a little different. The suspension may be different as well...hmmm...but if you say they're the same...
All they did is bore it out to a even 6.0... same as the 6.0 chevy truck motor. The heads are polished ls6 heads, the cam is the same spec as my '01 Z06 and the intake manifold has been upgraded to use a 90mm throttle-body.
Cruise-In II & IV Veteran
CI VI Drag Champ!
Next best thing to being there....video
http://www.challengevideos.com/2004/...09-04-B_07.wmv
http://www.challengevideos.com/2004/...09-04-B_08.wmv
There are a lot of changes to the engine. Just about all the sensors have been moved. This will affect which parts will work and which won't. We will be going through every thing to find out.
Yes there is torque management on 6spd cars. Any one that has tuned with edit can tell you about all the different tables. There is almost no difference in performance with the traction control turned off! We will be testing a module that will eliminate it.
I ran the 2005 Carlisle Callaway Corvette Project car this weekend at Beech Bend raceway this weekend at the best time we got was a 13.0 at 109 mph - totally stock. We will be running the car at the drags up here in CT this week again for another baseline run. I'll keep you posted if we break the 13 barrier.
Lance
Originally Posted by dads01dream
Hey Lance,
Where's there a 1/4 mile track to run the car in CT??
Thanks Dave for the info about TM, looking forward to seeing how you guys really wake-up that C6.
Lance
