Hooker Headers Blackheart C6 fitment
I bought these headers a year and a half ago and am thinking this spring to have them installed. Is anyone out there run these on a base 2005 LS2? if so did you run into any problems with fitment or any heating issues on your plug wires? Starter heat issues? Thanks for any input.
FWIW - Not specific to your product.
1) The steering shaft. There may be an indentation on the driver side header for clearance, once installed. Some modification to that indentation may be needed.
2) Spark plug wires. Yes, CoolSox (etal) heat/ burn protectors are items worth purchasing. Also depending on your wires, sometimes a 90 degree plug end cap vs a straight degree plug end cap can make a clearance difference.
3) Starter motor. No knowledge of issues, except others have commented about installing metal heat protecting shrouds. Because of Murphy's Law, I would purchase a shield to install while the exhaust is off.
Have fun with your project.
1320#me (03-14-2024)
Supporting Vendor
If you want a simple installation, you'll need to buy the hooker midpipe. Those will not mount to the oem midpipe. I do have Kooks headers and xpipe for C6 Corvette in stock and ready to ship if you can't find the midpipe or you don't want to wait for them to be built. The higher quality brands like ARH and Kooks won't do a slip fit connection to the midpipe btw. The less expensive options made in China tend to have funny fitment issues...Speed Engineering, Texas Speed, Hooker....
I had the Hooker Blackheart cat back exhaust installed a couple of years ago so it should match up fairly well.... or not we will see.
Supporting Vendor
Ah yeah definitely not going to fit. The hooker midpipe is a square fitment to the oem exhaust manifolds while the hooker midpipe designed for hooker headers bows out and meets the hooker headers at an angle.
__________________
http://www.corvetteexhaustsystems.com
845-476-8881
sales@corvetteexhaustsystems.com
201-575-0861 (cell to call or text)
Your Ultimate Resource For Headers, Exhaust Systems & more for Corvette! I carry Corsa, Kooks, ARH, Borla, Billy Boat, Akrapovic, Capristo & Much More
845-476-8881
