2009 Conv 6.2L LS3 CAN Wiring Diagram Troubleshooting
Hi guys,
I have a 2009 Convertible 6.2L.
All of a sudden I got bunch of OBD error codes with Check Engine Engine Light.
While the ignition was OFF, with a OBD break out tool, I tested the voltages of
So I think it is Bus A Off Short to Battery as the OBD suggests.
My most recent reading says, the communication is lost between ECU, TCU, BCM. U0100 , U0140 and U0141.
Any known problems ?
Any suggestions ?
Is the Radio part of CAN network ?
I guess I need to unplug each module one by one and test the network again, but that is beyond my knowledge for now.
Does anyone have the CAN wiring diagram as a reference?
Car Scanner ELM OBD2\
Version: 1.104.0/1.104.0/iOS
DTC report
Connection profile: Chevrolet OBD-II / EOBD (2004 - n.d.) + CANDate: 3/2/2024 4:00:01 PM
OBD-IIOBD-II
DTCs: 9
P0300 [0x0300]
Random/multiple cylinder(s) - misfire detected
Status: Confirmed
P0462 [0x0462]
Fuel tank level sensor - low input
Status: Confirmed
P0463 [0x0463]
Fuel tank level sensor - high input
Status: Confirmed
P0700 [0x0700]
Transmission control system, MIL request - circuit malfunction
Status: Confirmed
P1258 [0x1258]
Pedal Correlation PDS1 and PDS2
Engine Coolant Overtemperature - Protection Mode Active
Status: Confirmed
P2066 [0x2066]
Fuel gauge tank sensor B - performance problem
Status: Confirmed
P2125 [0x2125]
Throttle position (TP) or Accelerator pedal position (APP) sensor/switch E - circuit malfunction
Status: Confirmed
P2127 [0x2127]
Throttle position (TP) or Accelerator pedal position (APP) sensor/switch E - low input
Status: Confirmed
U0073 [0xC073]
Control module - data bus Off
Control Module Communication
DTC report
OBD-IIOBD-II
DTCs: 9
P0300 [0x0300]
Status: Confirmed
P0462 [0x0462]
Status: Confirmed
P0463 [0x0463]
Status: Confirmed
P0700 [0x0700]
Status: Confirmed
P1258 [0x1258]
Status: Confirmed
P2066 [0x2066]
Status: Confirmed
P2125 [0x2125]
Status: Confirmed
P2127 [0x2127]
Status: Confirmed
U0073 [0xC073]
Bus A Off Short to Battery;
Control Module Communication Bus A Off Short to Ground;
Control Module Communication Bus A Off Open;
ECU HS Bus Off;
ECU LS Bus Off
Status: Confirmed
Engine control unit
No DTC found.
I tested resistance of the CAN Bus and I got around 62 Ohm. ============================
Engine control unit
No DTC found.
[CAN high signal --> Body Ground] and
[CAN low signal --> Body Ground].
I got 0.88 Volt for both readings. [CAN low signal --> Body Ground].
Any suggestions ?
After you've ruled all that out, work on the codes.
Confirm main battery health before proceeding. A weak battery will take you on a wild goose chase after spurious DTCs. Load test if necessary. No-load voltage should be 12.5V-ish. Make sure the battery terminals are clean and tight. Make sure the starter connection is clean and tight. Replace the battery if it's old or was ever run dead.
The battery is fairly new.
I tested the voltage when the car was OFF, it was 12V +.
When the car was running , it is 14V.
ECU voltage was also 14.04 V
OBD voltage was 13.3V
I also removed the battery, cleaned the terminals.
I cleaned 2 grounds to the body as well under the battery, on the passenger side.
I checked the voltage with different ground points , and they were good.
I reinstalled the battery, and the connection is pretty tight.
I got the additional codes I mentioned above after I did all that.
I am also suspecting if this has anything to do with the random misfires P0300.
The car has random misfire issue on all cylinders when it's idle.
I am considering replacing ignition coils as well just in case.
The car has 150,000 miles.
Thank you
It does not misfire when the car is moving.
The diagram is for 2008 Corvette GMLAN but most likely they are similar.
Basically
I was able to come this far.
Basically
- ECM 120 ohm resistor
- EBCM
- TCM
- ESC
- VCIM
- BCM 120 ohm resistor
- DLC
Moderator, Tech Contributor
Received 2,135 Likes
Can H normally goes from 2.5 volts to 3.5 volts and CAN L from 2.5 down to 1.5 volts with engine running…you would normally see these voltages with a scope because these voltages are so fast and I measure them
in microseconds (millionth of a second)…with ignition on you would see 2.7 volts on CAN H and 2.3 volts on CAN L…if you’re seeing .88 volts sounds like the Bus is shorted to ground…as far as misfires the coil packs are pretty much bulletproof…take some time diagnosing and don’t fire the parts canon.
AraNe (03-13-2024)
C5 Diag,
Thank you for your reply.
Your reply is very informative with pictures.
I like it very much.
Unfortunately, I don't have a scope but I am planning to get one.
I followed some instructions from youtube.
I didn't measure voltages for CAN H and CAN L when the car was running or when the ignition was ON.
I should do that.
While the ignition was OFF Voltage Reading ..
OBD says BUS A. I don't know which circuit is BUS A.
There might be a problem with Radio circuit.
i don't know. I have to check.
May be I should remove the fuse for the radio and check.
I am thinking , if the short to battery was because of a cable, then most likely I was going to get battery voltage.
If the short is coming from an electronic board with low voltage, that's why I might be getting low voltage reading.
TCM might be causing the issue too.
i don't know how to check that one.
I will try to remove the TCM fuse under the hood #1, and try it again.
They could all be related.
I think it should be 14.7
Air to Fuel Ratio reading is blank on my OBD Scanner. I don't know if that is normal or not.
Anyways, it is challenging, but I am trying my best to find the problem with my limited knowledge.
Thank you for your help.
I should do that.
[[b]CAN high signal --> Body Ground] 0.88 to 1.2 Volt
[[b]CAN low signal --> Body Ground] 0.88 to 1.2 Volt
While the ignition was OFF Resistance Reading ..[[b]CAN low signal --> Body Ground] 0.88 to 1.2 Volt
[[b]CAN high signal --> Body Ground] No Value / Open Line
[[b]CAN low signal --> Body Ground] No Value / Open Line
The video said,[[b]CAN low signal --> Body Ground] No Value / Open Line
if there was a short to Battery, the voltage should be approximately same with Battery Voltage.
If there was a short to Ground , the resistance should NOT be open line.
My reading is very low voltage with open line .If there was a short to Ground , the resistance should NOT be open line.
U0073 [0xC073]
ECU HS Bus Off;
ECU LS Bus Off
My Radio is acting weird.Control Module Communication Bus A Off Short to Ground;
ECU HS Bus Off;
ECU LS Bus Off
P0700 [0x0700]
I also have random misfires.Transmission control system, MIL request - circuit malfunction
P0300 [0x0300]
I am getting Fuel/Air Commanded Ratio 13.37.Random/multiple cylinder(s) - misfire detected
Chevrolet Corvette (2009) – fuse box diagram
https://www.autogenius.info/chevrole...e-box-diagram/
1 Transmission Control Module/Transmission
9 Powertrain Relay Input/Electronic Throttle Control
56 Engine Control Module (ECM)/Transmission Control Module (TCM)/Easy Key Module
ECM Engine Control Module (ECM)
GM LAN RUN/CRNK GM LAN Devices
RDO/S-BAND/VICS Radio, S-Band, VICS
Ignition OFF - CAN H Voltage
Ignition OFF - CAN L Voltage
Ignition OFF - CAN H OHM Open Line
Ignition OFF - CAN L OHM Open Line
Ignition ON - CAN H Voltage
Ignition ON - CAN L Voltage
Ignition Running - CAN H Voltage
Ignition Running - CAN L Voltage
Ignition ON - Not Running - DTC No U or C Codes (ABS/EBCM/ESC)
Ignition Running - Additional Codes - Page 1
Ignition Running - Additional Codes - Page 2 Additional ABS/EBCM/ESC Codes C0450 C0561 U0073 U0100 U0101 U0140
Ignition Running - Additional Codes - Page 3
OBD Output when the Ignition is ON but NOT running.
DTC report
Connection profile: Chevrolet OBD-II / EOBD (2004 - n.d.) + CANDate: 3/13/2024 12:50:07 PM
Engine control unit
DTCs: 2
P0300 [0x0300]
General Electrical Failures [0x00]
Status:
DTC report
Engine control unit
DTCs: 2
P0300 [0x0300]
Status:
DTC supported by calibration,
Current DTC,
Test failed since DTC cleared,
History DTC, Test not passed since current power up,
Warning Indicator Requested
Current DTC,
P0856 [0x0856]
Traction control input signal - malfunction
Status:
P0856 [0x0856]
Status:
Transmission control unit #2
No DTC found.
EHU (Entertainment Head Unit)
No DTC found.
No DTC found.
No DTC found.
OBD Output when the car IS RUNNING.
DTC report
Connection profile: Chevrolet OBD-II / EOBD (2004 - n.d.) + CANDate: 3/13/2024 12:53:19 PM
Engine control unit
DTCs: 2
P0300 [0x0300]
Status: DTC supported by calibration, Current DTC, Test failed since DTC cleared, History DTC, Test not passed since current power up, Warning Indicator Requested
P0856 [0x0856]
Status: DTC supported by calibration, Test failed since DTC cleared, History DTC
No DTC found.
ABS/EBCM/ESC
DTCs: 6
C0450 [0x4450]
Steering Assist Control Solenoid Valve Circuit Malfunction; Steering Assist Control Solenoid Valve Circuit Open; Steering Assist Control Solenoid Valve Circuit Performance - Signal Invalid; Steering Assist Control Solenoid Valve Circuit High Current
Algorithm Based Failures: plausibility failure [0x5A]
Status: DTC supported by calibration, Current DTC, History DTC, Current DTC since power up, Warning Indicator Requested
C0561 [0x4561]
System Disabled Information Stored Engine Speed Out of Range; System Disabled Information Stored Acceleration Pedal Position Out of Range; System Disabled Information Stored Transmission Gear Invalid Data
Bus Signal/Message Failures: invalid serial data received [0x71]
Status: DTC supported by calibration, History DTC
U0073 [0xC073]
DTC report
Engine control unit
DTCs: 2
P0300 [0x0300]
P0856 [0x0856]
No DTC found.
ABS/EBCM/ESC
DTCs: 6
C0450 [0x4450]
C0561 [0x4561]
U0073 [0xC073]
Control Module Communication Bus A Off Short to Battery;
ECU HS Bus Off;
ECU LS Bus Off
ECU HS Bus Off;
ECU LS Bus Off
U0140 [0xC140]
Data bus, body control module (BCM) - no communication
U0140 [0xC140]
Lost Communication With Body Control Module Performance - Signal Invalid;
Lost Communication With Body Control Module Invalid Data;
Lost Communication With Body Control Module Message Counter Incorrect;
Lost Communication With Body Control Module Bus Signal Checksum Error;
Data bus, body control module (BCM) - no communication;
U0101 [0xC101]
Data bus, transmission control module (TCM) - no communication
U0101 [0xC101]
Lost Communication With Transmission Control Module Invalid Data
U0100 [0xC100]
Data bus, engine control module (ECM) A - no communication
U0100 [0xC100]
Lost Communication With Engine Control Module Invalid Data;
Lost Communication With Engine Control Module Message Counter Incorrect;
Lost Communication With Engine Control Module Bus Signal Checksum Error
No DTC found.
No DTC found.
When the Class 2 bus gets stomped on, you usually get key fob problems because the RCDLR doesn't work.
It looks like your scan tool is able to communicate successfully with modules on the CAN bus. Some of the DTCs are comms errors, but some of them are sensor malfunctions. That looks a lot like a power or ground problem.
AraNe (03-13-2024)
P0856 [0x0856]
Status:
I found
online.
It has to do with Ground problem to Traction Control Module
I also found
I actually cleaned that ground terminal.
And a video about
Does anyone know where the Traction Control Module and it's Ground are located for for 2009 Corvette ?
If you have any suggestions, please share.
Status:
History DTC
This might cause some general electrical failures.Test failed since DTC cleared,
History DTC
I found
I also found
And a video about
There are two buses in a C6: the CAN bus (GMLAN), and the Class 2 bus. The radio is on the Class 2 bus, along with the instrument panel, door controls, the HVAC, the RCDLR, etc. The BCM has a Class 2 interface, too. It acts as the bridge between the two buses.
Thank you for your reply and info.
I posted some videos related to Grounds and Traction Control Module.
I don't know where it is.
I think this whole thing is related to Traction Control Module including it's ground.
I will post again if I can find out more info.
Someone suggested the blue Left Connector under the Passenger Feet area is causing this problem because of loose connection.
I guess some passengers are putting pressure on the connector.
i will check that out.
Someone else suggested to clean the ground for Traction Control Module.
Thanks again.
TorqueTube,
Thanks again.
Thanks again.
The EBCM is integrated into the brake module at the left front of the engine bay. The ECM is behind the right front wheel well splash guard. The BCM is in the passenger footwell. The TCM (automatics only) is inside the gearbox.
AraNe (03-22-2024)
There is no separate traction control module. Traction control is managed by the EBCM (the ABS computer) with requests to the ECM (the engine computer).
ECM <--> EBCM <--> TCM <--> ESC <--> VCIM <--> BCM <--> DLC
I will check the and clean the Ground Connection for EBCM (ABS Computer) at the Left Front of the Engine Bay.
I will also check the connectors of BCM in the passenger footwell.
Someone under the comments of those videos said that after he added break fluid, his traction and service ride control messages went away.
I will check the break fluid as well.
Thanks again.
I checked the Blue connectors at the BCM and they were tight.
I didn't unplug them. I didn't know how, and I didn't want to force them.
Traction Control Switch, at the center console, gets power from Interior Lights System (Gry/Wht) and Grounds (Blk) at Base of Right "A" Pillar
(Attached pdf Page 2 of 2 at the bottom right )
Traction Control Switch connects to (Brn/Wht) Body Control Module (BCM) (1571 / 68 ) mounted on Toe Board In Right Footwell.
(Attached pdf Page 2 of 2 at the center right )
I am not sure when it turns off the Traction Control, when it has power (closed circuit ) , or when it has no power ( open circuit ).
I am wondering if the ground is a common ground with the radio at base of right "A" pillar.
I will research that.
BCM Location with it's Fuse Panel.
They don't usually come loose, but the contacts get dirty. To unplug, squeeze the blue housing and swing the grey lever over. The connector will be ejected by cam action. No need to pull on it.
AraNe (03-22-2024)
I found out some more info.
2009 EBCM is little different than the previous versions.
I took the attached photo.
I found some part numbers but I am not sure which one it is.
20777858 , 20777859 , 20777906 , 25780206
I also attached a technical bulletin from GM.
It may be a related issue.
2009 - 2011 Corvette: GM TechLink: Electronic Brake Control Module Communication
