Sending my head off to be "fixed"
Sending my heads off to Richard at West Coast Racing Cylinder Heads to have the valve guide and valves replaced( They are already ported)
I want to make sure my ducks are in order
Im planning on ordering:
1. Head gaskets
2. Exhuast man gaskets
3. Assembly lube
4. stuff to do an oil change
5. Rocker trunion upgrade kit https://www.glennsautoperformance.co...on-upgrade-kit
6. Coolant
Im planning on replacing the bolts with ARP studs Is it possible to get the heads-on studs with the engine in the car?
Is there anything else ill need car has less than 4k miles on it
1. Head gaskets
3. Assembly lube
6. Coolant
1. Head gaskets
3. Assembly lube
6. Coolant
1. Head gaskets
3. Assembly lube
6. Coolant
I had a C5 and I'm wondering if the engine is a bit further back in the C6Z. I remember doing the intake manifold in the ls1 to get to the oil sender was doable but took some fanagaling.
I replace the lifter buckets if you're going GM (and the little bolt that holds them).. ALSO the coolant o-rings from the little crossover..
It'll help to pour coolant into the block before buttoning it up -> did it on my first one, skipped on the next and I had temps of 235 deg just trying to get it warmed up.. it was warmed up alright! I had to squeeze the bottom rad hose like a million times to get the coolant circulated
(really spend time cleaning the deck.. I use a razor blade lightly, denatured alcohol w/ microfiber cloth.. WIPE everything down)
OH and almost forgot.. get the ARP thread cleaners(not thread cutters!)
I have successfully reused my exhaust manifold gaskets several times. It has worked for me......
KennyPowers (01-23-2024)
