2005 Tail light harness
Old 12-31-2023, 11:12 AM
FelixP
FelixP's Avatar
Default 2005 Tail light harness
I'm in the UK and recently fitted Infirai tail lights as I need orange turn signals here. They've been doing some strange things so I went to clean the main tail light harness connector. Well, that's my problem. It's badly corroded and some of the pins are hardly there. I can get a new tail light harness but it's 07 on. The pigtail adaptor is #88988066. It would be great getting the new harness anyway as the previous owner spliced the wires horribly to get a work around for the turn signals. My issue is the male side with the pins is on the car body harness. Can I get this pigtail somewhere? Could I skip the pigtail adapter and splice the 07 on male harness plug to my car and then plug the tail light harness in? Does anyone have a wiring diagram, I could even just solder on the tail light harness to the car loom?
Thanks in advance for your help!
Old 12-31-2023, 01:52 PM
crusher1
crusher1's Avatar
Can probably clean the connectors and contacts with crc electronic cleaner. I have used it for numerous electrical stuff and it works well
Any auto store sells it...
https://www.autozone.com/miscellaneo...1oz/128435_0_0
Old 01-09-2024, 10:45 PM
4SUMERZ
Race Car Tech
Support Corvetteforum!
4SUMERZ's Avatar
Received 2,333 Likes on 1,668 Posts
Old 01-09-2024, 11:15 PM
4SUMERZ
Race Car Tech
4SUMERZ's Avatar
Check with aescorvetteparts.com They may have the tail light wiring harness connector for a 2005 in one of the salvaged cars
Old 01-11-2024, 11:41 AM
FelixP
FelixP's Avatar
Thanks for the help chaps! I bought a new Delphi GT150 connector and a new harness, they just arrived from USA. I'll swap the harness out and change the connector and update you
4SUMERZ (01-11-2024)
To 2005 Tail light harness
Quick Reply: 2005 Tail light harness
