6L80 to TR6060 Swap
5th Gear
6L80 to TR6060 Swap
I have an 08 C6 with a blown fully forged 427 LS3. My 6L80 and Diff took a dump and I am now debating on swapping it to a TR6060 set up. Not due to power or anything but I just want a manual set up again. Reason I mentioned what /I have in the car is because no I can't just sell the car and buy a Z06 at this point. I have too much in it. Anyone know what needs to be done to do the swap to manual or have a bulletin with instructions. Thank you for your help ahead of time.
You are going to need a lot of parts! You need the bellhousing, clutch, clutch pedal, clutch master and slave cylinder, throw out bearing, manual trans torque tube and driveshaft, transmission, shifter and linkage, trans cooler and lines, manual trans console, and the differential shaft may be different.
If you found a wrecked manual trans C6 you may be able to purchase it cheaper than buying all the parts separately.
