A/c blowing hot on driver side only
I have gone over very many posts about the issue I am having. And have replaced the driver side blend door actuator and reset the system by pulling the hvac power fuse for longer then a minute then reinstalling. I currently have center console apart and can watch the blend doors complete their limit tests but the issue still remains.
Froen pressure is perfect, I have the dual zone system in my 2005 corvette. I'm getting 88 degree air out of driver side and 48 degrees out of passenger side
.02$ deposited.
Same issue with my 2011
My 2011 daily driver here in Florida just started this same issue. If I find out what is causing my driver side to be much warmer than my passenger side, I'll post the outcome here.
