Drivetrain noise
Drivetrain noise
Hello,
The other day at work, my car was idling in neutral and I heard two small clunk sounds about a couple minutes from each other. I drove home (45 minutes) no issues. The next day it drove fine until I turned to pull into my driveway and it made a clunk sound again and it felt like something shook near the rear. Yesterday I started it up and backed it out the garage to see if it would make the clunk sound again but it didn’t. I’m taking it to get looked at but I wanted to see what you guys think it may be or if anyone has experienced this. Torque tube was rebuilt two years ago with the clutch replacement. Maybe it’s the transmission going out or transmission mounts? Thanks for any suggestions!
As stated, hard to tell, and could just be a loose bolts in the works that needs to be tightened back up.
you have the access port on back side of the TT to check its bolts to the coupler plate (bolts 12 and 12, with 5 being the port cover. port 5 to check bolt 4) you can remove to check the bolts.
