Best Oil Barbell for 2005 Corvette
Replacing my main rear oil seal soon, and wanted to upgrade my oil barbell, which brand/s are the best.
I also heard something about the 2 rubber o-ring design being bad?
Edit: Also looking for suggestions for which brand rear main oil seal to get.
thx!
thx!
Received 3,089 Likes
2021 C6 of the Year Finalist - Modified
Upgrade to a "Billet Barbell' ..
What's wrong with just leaving the system the way it came from the factory ?
Is the factory setup flawed ?
666lisa (04-19-2023)
This one has better tolerances and filters out stuff in your oil at the same level as your oil filter. It also gives a better flow. And oil being so important, I’m more then happy to spend $30 for something that makes a permanent difference.
I used to do the bypass on older gen 1 SBC but haven't on any new engines. There was sometimes some grit around the spring that wouldn't get flushed through. My old thread: https://www.corvetteforum.com/forums...er-bypass.html
I’m looking at the sac city vette website and they also offer an oil Billet Bypass Delete. I’ve never really paid attention to the underside of where the oil filter screws in so I don’t recall if I have that check valve. Do you think I should also get one of those if I find my vette has it?
A stock barbell would also be fine and really is not a problem part at all. The Billet one is nice and if I was going to replace my rear main seal, I would likely get one. It does have tighter tolerances than the factory barbell. But as long as the o-ring is in good shape, the stock one is all you need.
As Turbo6TA pointed out, there really is nothing wrong with the stock one as long as its in good shape. So if you are doing the rear main seal, an OEM GM bar bell replacement is not a bad idea. The billet one is just a bit nicer.
A more worth while upgrade from SacCity would be their C6 Big 3 Wiring Kit. It is basically an upgrade for the charging system.
I got the sac city because of the reduced diameter of the skinny part. It fit perfectly in my ls2, no sanding etc required.
m295hv Melling pump as well.
The following 2 users liked this post by 0-60C6:
ClothSeats (04-19-2023),
itsonlyairandfuel (04-23-2023)
Improved racing has a very nice billet barbell.
https://www.improvedracing.com/ls-en...g-barbell.html
Sorry, another question because I like to be cheap.
For the rear main seal- is this one from C&S corvettes, any different from these 2 that I can buy on Amazon?
1-Better design Rear Main Seal
2-Crankshaft Rear Main Seal
Id have to purchase them separate from Amazon to get what I’d initially get all together from C&S.
Benefits from using Amazon is both items are prime, meaning I can return them for free if anything goes wrong, and a few other things.
The prices are almost the same, if for some weird reason C&S’s design is that much better. But they look identical so…
Have I mentioned I’m cheap?
thx!
thx!
apparently it is flawed. I’m still learning the ins and outs but I guess the plastic one in there has loose tolerances, and it’s also made out of plastic.
Hmmm i guess all this ls engines that have 300k miles on them should get a new one.. Not being a smart *** but i think stock proved itself. If ur saying they are failing that's new to me. Over 22yurs with LS engines never heard of one failing but i guess i wasn't looking for an issues all day searching the internet.
Oh stock is definitely fine, i also don’t believe I mentioned anything about a stock unit failing…
I'm just saying that this aftermarket one is better, and if your going to remove the entire drive train to tackle a clutch job and rear main oil seal like I am, why not upgrade this part for $25?
-Also not “looking for an issues all day searching the internet.”
Supporting Vendor
That said, the pans also switched to a M22x1.50 filter thread from 13/16"-16 in 2007. So the newer filters that do have a bypass valve won't fit the older pans.
More info here: https://www.improvedracing.com/gm-ls...mber-reference
If you want to delete the valve, and get a filter that does have a bypass valve, you need to find a 13/16"-16 filter with a bypass valve built-in. Here's a good resource we put together with info on filters: https://www.improvedracing.com/manua...erence%20Chart
Regarding the barbell, the factory one works okay but if you have the rear cover removed, you should replace it. Since it's plastic, they can deteriorate with time and allow more oil to bypass it. Our billet barbell performs better, seals better, and flows better, and it doesn't cost much more than the factory plastic one.
One of the issues with the barbells is that you can't get it to fit perfectly tight in the bore because there are some tolerances to the bore in the engine block. So to get a perfect seal, we added an O-ring to the tip of the barbell. With a metal valve, you will either be undersized, or you will have to sand down the barbell to get it to fit in the block. Either way, it's not a perfect seal.
You can purchase ours on our website or on .
The following 3 users liked this post by ImprovedRacing:
Supporting Vendor
But if ate broke don't fix it. Just my thoughts GL
Watched a YouTube video, guy was installing a billet aluminum barbell (not the ImprovedRacing unit) and it would only go half way into the block. He had to ream/debur the hole with a 5/8 drill bit with Vasoline on the bit to catch the shavings because of the extremely tight tolerance that the barbel was machined to.
