DiabloSport 8245 - A6's NEED it!
The other day I finally bought a DiabloSport 8245 for my 2006. I loaded the 91 octane tune and set the fans to full power, and also loaded the "hard" shift tune, then turned the pressures up all the way (+20%).
Now the car shifts like a performance car should from the factory. The shifts aren't old-school "bang" into every gear, but you do feel them. The car hangs on to gears now at part throttle instead of doing the "Clara Peller (young guys, can Google her) is driving", so get into 4th by 20mph thing.
At about half throttle it will hang onto the lower gears till 4K+ rpm, so when you want to get moving, no more need to paddle shift.
Speaking of paddle shift, they finally RESPOND when you click them, instead of waiting a second to mush into the next gear.
The engine tune also seems to be noticeable, and you do need 91 octane for sure with it.
I'm not seeing any mileage difference, but the performance is certainly better overall.
I give this a 2 thumbs up rating and certainly a must-have item for anyone with an automatic slushbox.
I'm sure a custom tune from DiabLew would be even better but I'm going to drive on this for a while as I have other stuff going on.
Sounds like you are happy with the results
If you had an option to run the fan (stock is only 1 fan on the C6) at 100% you should keep an eye on the temps as this is a sure way to melt the fan connector due to the increased amp load of the fan. You might want to return this option to stock and monitor to see if running higher is really needed.
Good luck and enjoy your modified Vette...GD
mcm95403 (10-02-2022)
I believe your 2006 draws air through both the front grill and underneath the front of the car. When was the last time you checked for obstructions in your radiator. There may be debris between the HVAC condenser and front of the radiator reducing the amount of airflow and resulting in higher temps.
Edit: just noticed you stated that temps are warmer since the install of a WP and T-stat (stock temp?). You may have some air trapped within the system when you drained & refilled. Look here for some C6 videos and tips to solve your cooling issue.
https://www.corvetteforum.com/how-to...wertrain-37480
GD
GD
diablo
bonjour jai acheter un diablo i3 platinum jai instalé sur ma corvette 2006 de base ,,octane 91 et augmenté la transmission hard plus 20% et aucun changement toujours lent à changement de vitesse,quoi faire diablo me répond pas très déçu,,tank you for reponse
I translated to English. I had the same result on my 06 but I contacted Diablo and they emailed a new trans tune that worked well.
[CITATION=JackDidley ; 1607682040]bonjour j’ai acheté un Diablo i3 platinum que j’ai installé sur ma base de corvette 2006,, indice d’octane 91 et augmenté la transmission dure de plus de 20% et pas de changement toujours lent lors du changement de vitesse, que faire diablo me répond pas très déçu,, tank vous pour la réponse
que j’ai traduit en anglais. J’ai eu le même résultat sur mon 06 mais j’ai contacté Diablo et ils m’ont envoyé par e-mail un nouveau morceau trans qui fonctionnait bien. [/CITATION]Je
Oui jai réussi à rejoindre diablo, il mon envoyé un update jai installé et toujours rien, la transmission toujours lent et aucun changement sur mes padel,,Jai recontacté diablo Pui il me réponde plus ,,,quoi faire ?
