Readout for A/C flashing on 2006
crawfish333 (05-13-2022)
To reset the HVAC control unit:
Press both defroster buttons and the fan speed up button together, all three at the same time. Acts like a soft reset for the system.
To calibrate the HVAC ventilation mode door actuator:
1. Turn OFF the ignition.
2. Remove the battery positive voltage circuit fuse of the HVAC control module (HVAC/PWR SND 10A located in passenger side footwell).
3. Wait 60 seconds, then reinstall fuse. Important: The module memory will not clear if the battery positive voltage circuit fuse is reinstalled in less than 60 seconds.
The following 2 users liked this post by ClothSeats:
crawfish333 (05-13-2022),
tommyc6z06 (05-14-2022)
