Low dust brake pads
Low dust brake pads
Hi folks, I知 in the market for low dust brake pads. I知 tired of my expensive wheels always looking dirty from the stock pads. I can spend hours cleaning the wheels and one drive and they池e filthy again. Please advise thanks folks.
Notover (12-18-2021)
Supporting Vendor
St. Jude Donor '11,'13
For a high quality low dust performance street brake pad take a look at the Carbotech 1521 brake pad 100% non-corrosive dust will not harm your wheels, paint or rotors. Carbotech brake pads are 100% made in the USA and contain NRS Technology Here is a link to explain further what NRS technology is exactly: http://www.nrsbrakes.com
Carbotech brake pads can be ordered by calling me at 216-780-8825 Or order direct Here Ampd Autosport | One of the Largest Internet Retailer of Carbotech Per – Amp'd Autosport Use promo code z28 at check out for your forum discount.
The Carbotech Bobcat 1521™ is our high performance street compound that is our most successful compound. The Bobcat compound is known for its awesome release and modulation, along with unmatched rotor friendliness. Like our AX™ & XP™ line of compounds, Bobcat 1521™ is a Ceramic based friction material offering minimal rotor damage and non-corrosive dust. Bobcat 1521™ offers outstanding performance, even when cold, low dusting and low noise with an excellent initial bite. This compound’s virtually perfect linear torque production provides incredible braking force without ABS intervention. Bobcat 1521™ operating range starts out at ambient and goes up to 900ーF. Bobcat 1521™ is suitable for ALL street cars, perfect for your tow vehicle, police cruiser. The Bobcat 1521™ compound has been found to last two-three times longer than OE pads you can purchase at a dealership or national retailer. That’s one of the beauties of Carbotech Ceramic brake compounds. Bobcat 1521™ is NOT recommended for any track use.
__________________
Adam Adelstein
Amp’D Autosport.com
Internet's largest retailer of Carbotech Performance Brake Pads.
PH:216-780-8825.
Email: sales@ampdautosport.com
Web Site & Direct ordering http://ampdautosport.com/
All major CC and Pay Pal accepted.
Check out Promo code:z28
__________________
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Received 3,089 Likes
2021 C6 of the Year Finalist - Modified
BigButtLover (06-06-2022)
There are LOTS & LOTS of options out there. I would suggest going to the C6 Tech Forum and doing a search on Brake Pads. Numerous posts about the dusting issues - particularly on the GS / Z06 with the puck pads or "padlets". Many people have experienced the same issue you have - and most have changed the pads to something from the aftermarket.
I went with the EBC Redstuff, but I would strongly encourage you to do some reading about what other people have done, and their results. Not everyone has been completely happy with their choices. It seems that the Duralast Gold, the Carbotech, & the Performance Friction Ceramic pads are the most popular choices.
A number of posts have also indicated that getting the wheels really clean and applying a Ceramic Coating has helped the clean up process. Certainly worth thinking about....
If you would like a low dust pad that still has excellent stopping, check out Hawk HPS pads. Have them on my C6 and used them on my 99 Z28.
very low dust (compared to the factory pads), very low noise, and great bite. I love them.
dar322 (12-30-2021)
Thanks folks. Lots of options for sure. Doesn't make my decision any easier lol...
Performance Friction, Carbon Metallic (not carbon ceramic).
I would stay away from any ceramic brake pads since they are designed for low dust, low noise, at the expense of stopping power. Ceramic pads are not performance brake pads.
Adam@Amp'dAutosport.com (12-26-2021)
I switched to the Hawk 5.0 for the same reason, brake dust was really enoying. These work great and 80% of the dust is gone. They do not have the initial bite as the oem pads but they work great.hawk hps 5.0hawk hps
A high quality ceramic pad on a C6 is not going to be inadequate in any way for some mildly spirited street driving and will barely produce any dust at all.
sramzzz (12-29-2021)
joeybsyc (06-07-2022)
Running Akebono ASP pads currently. No noise, good bite. So little dust it takes many excursions of moderate-to-hard driving to be able to even find residue via finger wipe. At that point it's still not really visible on wheel. Highly recommend for street application.
I just switched over from the Duralast Gold Ceramic pads to the PowerStop Z26 pads. The PowerStop pads definitely perform better. No dust.
The Duralast Gold pads are definitely good and low dust but mine started to squeal everytime I braked.
