Upgrade base suspension
I've been doing a lot of reading, and I'm starting to confuse myself. I have a 2013 Base C6. I find the suspension a little soft for spirited driving. I would like to have it a bit more sporty, without overly sacrificing ride quality. I have upgraded the sway bars to Z51. This helped keep the car a bit more planted, but it still feels a bit too soft.
I have read about the following options:
1) Upgrade to Z51 shocks (FE3 suspension package).
2) Upgrade to Z06 shocks (FE5 package?)
3) Upgrade to Bilstein B6 shocks
Option 3 is the most expensive. I found a good deal on option 1 from Rock Auto.
I don't want to upgrade the springs at this point. Can someone explain to me the differences and benefits of each approach?
I've been down this road... I'd go with the Bilstein B6 if doing it all over again and spirited highway driving was my objective. The B6 (or B8) are not much more money then the OEM's and they are a much better shock all the way around. If you want to stiffen the ride up alot go with the B8's.
FWIW - I'm currently running Bilstein DRM's and they would be to stiff for most people and highway driving in my humble opinion.
Hope that helps.
Hope that helps.
Thank you! Yes, this does help. I read somewhere that the Z51 OEM shocks are made by Bilstein. I found the OEM to be about 1/2 price on RockAuto compared to the Bilstein.
Last time I looked Bilstein were only $100 more than OEM. Doug Rippie Motorsports usually has a great price, also check Tire Rack.
The OEM Z06 shocks will be an up grade from base and stiffen the suspension. If you're on a tight budget nothing wrong with this approach. But there is a reason when many Z06 owners replace their shocks they upgrade with Bilstein ;-)
wideglideleon (09-22-2020)
I'm a big fan of the huge LG sway bars. They're much larger than any of the EOM bars.
Won't effect the ride quality, body roll will become imperceptible, and can be installed easily without regard to shock tuning, etc.
(check your bushings too)
So I have a 08 base and have upgraded the suspension and here are my thoughts. The stock suspension is awful.
First I upgraded to Z51 sway's with poly bushings and Moog Endlinks. Next I installed Bilstein B6 shocks. After 4k miles I wanted a more firmer ride (I live in Michigan) so I went ahead and installed B8's.
The B6's rode very smooth but the B8's will make your base feel more like corvette then a Cadillac per say.
Next upgrade the motor and trans mounts with Hinson motor sports mounts. Totally transformed the car. I am also running Michelin Pilot Sport 4s tires.
Good Luck.
Good Luck.
I'm pretty pleased with the ride and performance of the Z51 bars and Z06 shocks. I don't think the ride is too harsh by any means. I'm sure it's a perception thing though. Different strokes for diff folks I guess. I have a set of RR tracks I have to go over whether I'm going to work or play. I go over them at 20 mph. No creaks, rattles, or other tight ride issues. Used to have a little top noise, but since I started using the swimming pool o-ring lube, all that is gone.
Good Luck.
Good Luck.
JackChesbro (09-21-2020)
This suspension NEVER should have been put on a Vette.... it's terrible !!! ... it's for old men that like a "floaty" ride like an old Cadillac and drive 55 on the interstate..... I've passed plenty of them and just laugh; why the heck would you buy a Vette and get passed by semi trucks ???
SORRY.... got side tracked there ....
Anyways, when I bought the car, it had 14,xxx miles and still had the original Goodyear run flat tires. SO... I had alot to change in order to get this car firm and stable.
I replaced the tires with General G-Max RS, installed Bilstein B6 shocks, and also replaced the sway bars with WCC (West Coast Corvette) #33110050 (Progress Technology # 63.0480). These sway bars are a bit stiffer than the stock Z51 bars.
All I can say is these 3 upgrades transformed the car...
- Tires allowed me to accelerate way more aggressively out of turns; the Goodyears were 11 years old and slick as snot ! ($760 from Tire Rack)
- Shocks really firmed up the ride without being harsh; I highly recommend these. ($425 from Amazon)
- Sway bars flattened the cornering without any difference in ride quality. ($370 including shipping from West Coast Corvette)
So there you have it... I would definitely go with the Bilstein shocks; the B6's if you want a firm, controlled but not harsh ride.
You guys convinced me. I already have the Z51 sways, and I just pulled the trigger on the B6. RockAuto was the best option to get these into Canada. Sadly the Canadian distributors charge a SUPER heavy premium (despite "free" shipping).
Now that your done insulting the old folk. Did you ever think(I don't think so) that they built the base model to sell a few parts or most likely the real reason is that the base is cheap and easier(less waste ) to strip for racing. I know it's hard but if you think about it that's why the base and ZO6 have the same transmissions and gear ratio. Pro's don't buy a Z51 to strip for racing. GM meant them for guys like you.
