Injectors cause issues?
So I have been getting my car ready for spring. Finished up stereo, working on seat skins, etc.
I pulled the coil packs and put loctite on bolts because they came loose. While I was in there, I replaced my stock injectors with the 60# that came with my A&A kit. Proceed to do oil change since I had the valve cover off (hidden coil covers) . When I started it after oil change, it ran like crap. Barely stayed running.
I'll be starting the A&A install soon, but want to make sure there isn't another issue.
I'm assuming its because of the bigger injectors?
Supporting Vendor
