changing the differential oil, how difficult?
Regarding my 2012 G.S. Corvette auto How difficult a job is changing the differential oil ?
and what brand of oil would you recommend and will I need a bottle of anti chatter oil ?
thanks Boonie
thanks Boonie
Very easy. buy the little pump attachment for like $5
You can find the gear oil on Amazon by part number for 10 bucks less per quart than most dealerships sell it for.
It's a simple drain and replace. Youtube has several videos if you want to see it done before you do it.
Very easy. Took me less than a half hour including searching for some wood blocks to drive the front onto before jacking up the rear.
Definitely buy the hand pump made for the bottles.
Stopped the clunking at low speeds after doing a few figure 8s
