AC Warm on Driver Side But Cool for Passenger
Old 07-13-2018, 07:32 AM
frankz06_cf
frankz06_cf's Avatar
Default AC Warm on Driver Side But Cool for Passenger
A while ago I had this odd problem where the driver side of my 2007 Corvette blew warm air from the A/C but the passenger side was always cooler. I searched here on the forum and YouTube for any ideas. I tried pulling out the relevant fuses but that did not work. I took it to the dealer where it turned out that it was leaking Freon from the seal in one of the lines. Since then it has been perfect.
I wanted to post this in case any one has the same problem in the future.
Old 07-14-2018, 12:10 AM
kctecser
kctecser's Avatar
Interesting, I have the same problem on my 2007. Not a dramatic difference in temperature, but the driver's side is always warmer.
thanks for the post
Old 07-14-2018, 05:29 PM
88redconvert
88redconvert's Avatar
My C5 did that and it was low on Freon also.
Old 07-16-2018, 10:24 AM
HT1663WB
HT1663WB's Avatar
Definitely low on freon.
Old 07-17-2018, 10:34 AM
frankz06_cf
I'm glad it has helped some people. I meant to include that my mechanic told me that the passenger side remains colder because it is closer to the line. He said it in a more technical manner but that was the general meaning he gave me.
Old 07-17-2018, 11:51 PM
c6moneypit
c6moneypit's Avatar
I had problems with my ac twice last year. Each time the driver's side was warmer as you described. Turns out I had a Freon leak. If the pressure is not at the exact level needed, then it can affect the compressor output even if there is Freon in the system. So each time they recharged it, the ac was ice could for a while then it would happen again. Turns out my condensor had a small leak. Got it fixed and has been perfect ever since.
frankz06_cf (07-22-2018)
Old 07-18-2018, 03:35 PM
Scott S
Scott S's Avatar
That's a sign that the A/C needs to be recharged. You can get a simple bottle at an autoparts store. Pretty easy to do. $20 and 20 minutes.
To AC Warm on Driver Side But Cool for Passenger
Quick Reply: AC Warm on Driver Side But Cool for Passenger
