Kooks headers, x-pipe and custom tune - 50 RWHP
So I couldn't be happier. Got myself Kooks 1 3/4 headers, ceramic coated inside and out....and the Kooks x-pipe with the green cats...and had the exterior of that ceramic coated as well.
Great guy named Chris Simpson...did the work and the custom tuning. Was going to note the type of dyno he had, and forgot to. But it's super conservative. On the baseline dyno run before the work, my 2010 GrandSport, manual, put down 325 to the wheels. When we did SAE correction it was right close to 360 I think.
Anyways...after a full day on the dyno, end result was right around a 50 rwhp gain. Impressive. Even he was impressed on how much we gained. Pretty sure there was about 10-15 hp to be gained just from tuning if nothing else though, as it was dumping fuel on the stock tune. Like 10.5/1 AF ratio on the stock tune....which is just ridiculous. Also tuned out the 1-4 skipshift bullshit, lowered the temp for when the cooling fans come on....running cooler now. Runs like a bat out of hell now.
Corvette dyno results.pdf
Nice. Plan on adding anything else, like a supercharger? Think I want to install a 1 7/8th ceramic coated or jet black LT headers, X-pipe to stock NPP myself, then get a tune from somewhere, see how it feels, then go self contained centrifugal, either AA or ECS,
DOUG @ ECS (07-06-2018)
I just don't think it's worth it personally. I might pick up a bit more gains, but the stock filter is so efficient...that I don't really see the point and would rather spend money elsewhere.
I'm doing a cam swap, valve springs, etc...next year. Because I spent the money on the catted x-pipe...sticking to naturally aspirated power. Apparently adding boost is likely to destroy the cats....and quite honestly, with a cam I should be up to around 550hp at the crank and will spend additional money on suspension pieces. Plan to do a supercharger build on my '18 Mustang for a high horsepower beast.
Was looking under the hood last night after a good run around the town....and noticed that just one of my plug wires is barely touching the header. Just at the top of the wire on the bulky hexagon rubber head. All the other ones have lots of space from the header.
The only way I can see solving the problem is to remove the stock metal plug shield and possibly use different wires. But if I do that, then I assume I'll have to remove all the metal shields and replace all wires. Damn it.
Premium Supporting Vendor
Location: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Received 1,090 Likes
