DIY Caliper Swap
Old 01-14-2018, 05:50 PM
C6C3Vettes
Support Corvetteforum!
C6C3Vettes's Avatar
Default DIY Caliper Swap
I purchased new a 2013 blade silver M6 GS coupe that I've done a few mods on and get to the track 5 to 6 times a year for HPDE events. Some of the mods are LG long tube headers, coil over shocks, short throw shifter, etc. all of which installed by LG. I recently purchased a 2013 VY A6 vert GS that's become our cruiser.
The blade silver coupe had yellow calipers from the factory that I never really cared for. The VY vert has silver calipers with red Corvette lettering.
How difficult would it be to do a caliper swap between the 2 cars? I use DOT 4 brake fluid on the coupe that I HPDE and change it regularly myself and have also replaced brake pads and rotors on my own. I'm a beginner to intermediate DIYer and would like to try doing it, but wanted to ask before I take the plunge.
Thanks in advance.
Old 01-14-2018, 09:54 PM
timd38
timd38's Avatar
Couple hours of labor and several pints of brake fluid. I would put stainless lines on at the same time.
C6C3Vettes (01-14-2018)
Old 01-14-2018, 10:55 PM
C6C3Vettes
C6C3Vettes's Avatar
THANKS!!! Good idea on stainless brake lines.
Old 01-14-2018, 11:17 PM
96GS#007
96GS#007's Avatar
Received 1,766 Likes on 1,063 Posts
Waste of money to change the lines IMO. Also....do a search and see how many people have had issues changing the lines. Multiple instances of people finding one of the fittings on the hardline deformed making it difficult to get a seal.
As far as the caliper swap....as mentioned above, just a couple hours. If you have both cars up on jack stands you can swap them quickly.
I would buy caps for the lines so fluid isn't simply draining out while you have the calipers off running between cars. You will also need new crush washers.
Old 01-15-2018, 12:37 AM
Dano523
Dano523's Avatar
Received 3,028 Likes on 2,182 Posts
Also to point out, will need a tech II handy, since when you go to bleed the brakes in the end, may need to cycle the ABS pumps in each car to get air out of then during the powder flushes.
Old 01-15-2018, 01:47 PM
RPOZ4Z
RPOZ4Z's Avatar
Cruise-In VII Veteran
not if you don't loose a lot of fluid.. cap the lines to prevent that much fluid loss.
changed all four calipers on my C5 and didn't need a techII.. just bleed them like normal.
Old 01-15-2018, 04:24 PM
timd38
timd38's Avatar
I went from Z51 to Z06 to Wilwoods and never used a tech II.
Old 01-15-2018, 04:27 PM
timd38
timd38's Avatar
I have installed three sets of quality stainless lines with zero issues.
Stock calipers, Z06 calipers and Willwood calipers. Some people just should not be working on their own cars.
Old 01-16-2018, 11:51 AM
96GS#007
96GS#007's Avatar
No offense to the OP but when someone describes themselves as a beginner to intermediate DIY, there's a pretty good chance they don't have the right tools for the job.
To DIY Caliper Swap
Quick Reply: DIY Caliper Swap
