Throttle body
Throttle body
Just a quick question;
If I get my throttle body ported, then the computer will detect more airflow and compensate with more fuel - correct? If so, will that make the 02 sensors (or some other sensor) freak out a little and counter that result?
Its an 05 coupe, non zo6, A4, Halltech CAI, B&B cat back exh.
Thanks in advance
Thanks in advance
No problems at all will be encountered ....the ECM has plenty of room to compensate for a ported throttle body .... but on a stock car you will not see any gain .....put the money towards a intake manifold or headers ....
Dave
Dave
Won't see peak power gains, but a ported TB can show gains on throttle response and how the car drives if that is what you are after. If it is just more power, then skip it.
vetsvett (12-31-2017)
Yep, GM played with the inlet shape of the TB to get a good flow balance around the entire vain movement percentage openings.
With some porting, the flow is not longer even close to linear across the vain's travel positions, making the car much harder to drive in actual street type driving conditions (semi turning the TB into more of an on/off switch instead).
Hence before you go to have a TB ported, have them print out a flow chart of the TB flow volumes through the vain's opening percentages, then another flow chart of throttle percentages after it ported. In oem, the flow is pretty linear with the different TB vain positions, while in the ported TB, no very linear isntead.
http://www.mikenorrismotorsports.com/Home_Page.php
