2010 custom tune question
about 30 hp, throttle response will be much improved, well worth the $ if done right. if your any where near Atlanta ga get to Vengeance racing in Cumming ga
I went form 376hp/382tq to 400 for both. Rear wheel.
2008 MN6 LS3. With 800 miles on the odometer.
A Dynapack was used, wheels off measured at the hub.
Even without a power gain, the reduction of torque management, skip shift, speed limiters, etc are worth a tune.
Auto for the shifting alone is worth a tune. 2010s are 6 speeds so do you mean 6 speed manual or auto?
looking in HPTuners the speed limiter on my corvette is in the high 200's
Depends on shop.
Most are a set rate depending on setup. Some are by the hour. $400-500 for a tune on dyno is typical. Crazy n2o or FI setup maybe $100 or so more.
Depending on price, even without looking at peak HP gains (10-15rwhp or so) you disable skip shift, adjust fan settings to run cooler and maintain more peak power, adjust IAT tables to not pull timing as easy, reduce or eliminate torque management which reduces power in lower gears, adjust speed limiters, etc. So if that is worth the price of the tune, go for it.
My fear is there are no reputable places near me to trust tuning my car. There are some around but how do I know he has experience doing a vett. I see a lot of pickup trucks around these places and a couple Ford Mustangs, but kind of scared to turn either my 2 cars over to people around here.
mine charged $500 for the first one an then about $175 for 'retunes" I've done one retune and am going back next week
