Always set the parking brake with an automatic transmission
Old 08-05-2017, 12:00 PM
CSIXVET
CSIXVET's Avatar
Default Always set the parking brake with an automatic transmission
I recently had the shifter cable break on my 06 coupe, this allowed the car to roll even though it was indicated to be in Park.
I was still in the car and applied the parking brake before there was a collision.
I will now always set the parking brake before exiting the car.
Just a heads up for automatic car owners.
Old 08-05-2017, 03:17 PM
Icecap
Icecap's Avatar
Always a good idea to use that parking brake C6VET, my pet peeve is family members that park on a hill and then let the car roll into the Parking Brake Pawl in the transmission which torques up the driveline before they set the parking brake. Next person to drive the car has to apply excessive force to get the transmission out of park and then it releases with a big Twang.
Old 08-05-2017, 09:06 PM
Not So Fast
Not So Fast's Avatar
Thanks, good advice not always followed
NSF
Old 08-06-2017, 10:26 AM
Vettereturned
Vettereturned's Avatar
Well said I cannot agree more... years after explaining what takes place within the car my wife is good at setting the parking brake, releasing the foot brake then shifting into park. She is also good at stopping before shifting into drive and slightly rolling when turning the wheel hard over.
Old 02-19-2021, 09:59 PM
Wrencher
Wrencher's Avatar
Default Diff Rubber snubbers
Great photo of the rubber snubber, but it is the upper half that goes bad! you can't see it without a mirror, and even then it's tough to see. When I finally took the bolt out and reached in there, all I got was rubber bits and dust! totally solved the clunk I had for years, I used poly bushings..
Hans
Old 02-20-2021, 09:24 AM
PCMusicGuy
PCMusicGuy's Avatar
You could of course move to a place where everything is so flat and level you don't need a parking brake.
cdm747 (02-21-2021)
Old 02-21-2021, 08:12 AM
cdm747
Support Corvetteforum!
cdm747's Avatar
St. Jude Donor '17-'18-'19-'20-'21-'22
Yeah, living on the Gulf Coast all my life we always called it an emergency brake not a parking brake.
Old 02-21-2021, 01:15 PM
Dano523
Dano523's Avatar
Received 3,032 Likes on 2,185 Posts
Got to love Hilly coast areas like CA, where you can get a ticket for not having your wheels clocked the correct direction or enough when the car is parked on a hill as well.
IIRQ, it was like a $175 dollar ticket in SD when parked up the street hill at Windansea beach since I didn't have the front wheel cocked enough that if the E brake let loose, car was not going to end up in someone yard fast enough.
To Always set the parking brake with an automatic transmission
Quick Reply: Always set the parking brake with an automatic transmission
