Garage lifting system(rocker)
Does anyone know of a compact garage lifting system to go under the rocker rail to facilitate easy lifting on lowered cars? Almost like a projack but goes under the rocker for unibody cars.
Phil
Phil
You can slide them in from the side if you want
I have the 7000 which is 1/2" higher than the 5000 when fully collapsed. I leave mine down all of the time and ride over them whenever moving the car in and out of the garage. I have them positioned just inside the wheel base, leaving about a foot gap in between them. This is to allow room for the headers, which may sit lower than the stock system. I don't leave the rubber lifting blocks in place though, as these may not leave enough height. So when I want to lift the car, I pull the lifts out the side slighty, drop the blocks in, and slide them back into position to lift the car. No issues. And again, this is with the 7000 which is higher.
