LS2 mass air flow sensor screen
Hello i have an c6 ls2 and was wondering if it will affect the car if i removed the mesh screen that is located in the mass air sensors front? i put a cold air kit and wondering if it would cause any issues if i removed it ? than you for your feed back.
Received 1,194 Likes
St. Jude Donor '15
Do not remove the screen
Best case nothing happens, worst case it increases turbulence across the MAF and readings end up all over the place. It's there for a reason.
ConanElBarbaro (11-11-2016)
Your Lucky.....A lot of people have problems after removing the screen, like mentioned above it smooths out the air flow for a more consistant MAF reading.. . I don't understand the logic behind removing the screen, it's not going to improve anything with either your hp or gas mileage so why screw with it?.....WW
