70 inch APR rear wing and trunk question
Does anyone know if the truck lid can still open if you have an APR 70 inch wing on the car? Seems like it would get in the way. I'm in the market for a wing, but my car needs to be "practical" as well.
Thanks!
Thanks!
I have the 70" APR wing and it adds enough weight to the hatch so that it won't stay up. I found a replacement strut company on eBay and using the formulas and measurements posted, moved up two numbers from the stock hatch struts and it's working fine so far. Couple of other friends with the same wing just use a prop rod to keep the hatch open when loading and unloading stuff from the cargo area.
EyeMaster (06-27-2016)
Former Vendor
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13
Why not frame mount the wing?
https://www.corvetteforum.com/forums...rear-wing.html
Without a proper support from the frame up to the hatch, you are getting a lot of movement back there if all it is mounted to is fiberglass.
Geewez:
I used a company called Lift Supports Depot on ebay. Go to liftsupportsdepot.com and check out their site. Do a search on these two part numbers: 4516 and 6522 and compare the specs to the stock apps for your year C6. I used a pair of 4516 struts. But you'll notice part number 6522 says for aftermarket spoiler cars. You can also see a picture of the rear wing on my C6, I posted a picture of the rear of my car a few pictures after yours. I'm using the same wing as yours, the APR GT500 70" wing except we're not using the aluminum legs that come with the wing. You can see on my picture we're using a custom made mount for the wing which I think looks better than the APR mount. Hope this helps.
Me:
Awesome, thanks man! I did some digging and saw that 4516 says OEM equivalent. I ordered a pair of 6522s to give it a whirl. We'll see how it goes.
Final outcome: the 6522 set was legit.
I see ur point. I haven't had any issues with my GTC500 and I have not seen anyone replace or modify their springs after a wing was added with Magnetic Ride.
that's what I am saying..plus most of us driving our cars will be street driven as well. Issue free here after 400 miles done in 1 week. Did a handful of 150mph pulls on the highway. No cracked deck lid..no suspension issues.
