Upgrades with Cam Install?
I'm shopping around to get a cam install on my LS3 A6. I have a pretty good idea of the specs of the cam, but was curious if there are any other maintenance items to have done at the same time.
I am planning to have the crank pinned while they are in there to make a supercharger that much easier if I were to go that route.
Please let me know if there are any other items I should have addressed that I can save labor on while they are in there.
For reference, my car is a base LS3 A6 w/ 40k miles.
I've been looking into a somewhat mild street cam for my 2013 GS MN6. The shop I've been working with recommended to get a set of Shaft Mount rockers to add valvetrain stability & longevity to my build. They are pretty expensive though. Personally, I'm going to hold off on a cam for my car until I can afford, (w/extra mod money) to buy the shaft mount rockers & cam at the same time. (Personally, I don't mind waiting a while so I can get a rock solid build)
(http://texas-speed.com/p-359-comp-ca...2-engines.aspx)
Former Vendor
I highly recommend the following with any camshaft install, with the exception of the obvious gaskets/seals/hardware:
Melling high volume oil pump
C5R timing chain
Trunion upgrade
ARP camshaft bolts
Dual valve springs
Hardened pushrods
We do include all of these parts as well as the 3-bolt conversion for our camshafts and all gaskets/seals/hardware for install in our Cam Kit Plus if you're interested in running one of our grinds.
http://vengeanceracing.net/vengeance...plus-1446.html
Feel free to give me a call or e-mail at david@vengeanceracing.net if you'd like to discuss anything further!
- David @ Vengeance
C5R timing chain
Trunion upgrade
ARP camshaft bolts
Dual valve springs
Hardened pushrods
- David @ Vengeance
