Z06 water pump seeping coolant, which pump should I go with?
Looking at the ACDelco Pro to replace stock water pump (stock pump started seeping from weep hole), but see that there are a few other manufacturers I could buy instead. Does anyone recommend to go with a Cardone Select or Gates instead of the OEM?
